Battery charging maintenance ?
Posted: Thu May 22, 2014 12:08 pm
by FAT BOTTOM GIRL
I just bought 2 new batteries for the boat. There is a battery tender that is always pluged in tending just one battery. Is it ok to b pluged in all the time when hooked to shore power or generator or should it b unplugged more often ? I'd like to put switches on the positive charger lead & b able to switch to maintain the other battery.
Re: Battery charging maintenance ?
Posted: Thu May 22, 2014 12:49 pm
by OK Toon
As long as they are already fully charged, they make splitters that can be used with tenders -- so you can maintain multiple batteries. I have mine split 3 ways so over the winter I maintain 2 batteries being stored for the boat and another split goes to my mower battery to keep it maintained as well.
Just remember, these units are only to maintain a charged battery (hence the name, battery tender) -- they won't charge a weak battery. And if you do connect it to 2 batteries and 1 of the batteries is not fully charged, it will drain the good battery and could damage them both.
Posted: Thu May 22, 2014 12:53 pm
by Bryden24shp
Where did you get your splitter? I want one!!!
Posted: Thu May 22, 2014 12:59 pm
by Capt Sully
I have a on board 2 bank charger / tender that is always on if I'm not on the lake with the toon. Been doing this for over 2 years no problems. If you have the battery that needs water, then you need to keep up with that.
Posted: Thu May 22, 2014 1:30 pm
by OK Toon
I use a Battery MINDer from Northern Tool but I would think they are pretty much interchangeable.
Here's the splitter
http://www.northerntool.com/shop/tools/ ... _200577248
Here's the extension cable (that I use to take a lead over to the mower batter)
http://www.northerntool.com/shop/tools/ ... _200577247
Here's the additional terminal assembly to go on the battery from the splitter
http://www.northerntool.com/shop/tools/ ... _200622842
So far I've been able to get 3 seasons out of my mower battery where before I'd have to buy a new battery every spring. This was the first year I used it to maintain my boat batteries over the winter. But when I disconnected it from the tender before putting it in the boat, it was still fully charged and the boat fired right up.
Posted: Fri May 23, 2014 1:05 pm
by FAT BOTTOM GIRL
Thanks for the feed back. Keeping an eye on the fluid level is important true.
I was concerned about constantly charging(tending) a battery & if there is more
harm or good ? I am thinking of putting two switches on the positive lead of the
tender so as to turn one off as the other is on. That way I could keep both batteries
tended to.
Posted: Sat May 24, 2014 11:05 am
by bassn386
My $0.02 worth. I only use a battery tender when I put the toon up for the winter. Never have had a problem starting her in the boating season, even if it's been a couple of weeks between uses. Of course, if I leave the Master switch in the On position that changes everything, but that's not the battery's problem.
Posted: Sat May 24, 2014 2:09 pm
by cwag911
Remember like Ron Popiel said," Just set it and forget it." Tenders are made to do just that, "tend".
Posted: Mon May 26, 2014 4:06 am
by rancherlee
I have all my batteries linked through a 150amp rated cut off switch so I can charge the troller pack/house batteries and the starting battery at the same time with 1 tender. I'm now on year 7 with these 3 batteries and no sign of weakness.
Posted: Mon May 26, 2014 4:13 am
by robster
Correct me if this is a false statement,but I've read that a fully charged battery will last longer,and of course always keeping the fluids topped off.
Cheers,
Robert
