kenwood marine radio
chopper6358
#1 Post by chopper6358 » Wed May 28, 2014 12:25 pm
my kenwood marine stereo gets wet in a rain storm one time and its done! so much for you get what you pay for.
1998 Crest 25' Tritoon,115 Johnson 2 stroke. 13x11 4 blade spitfire prop, pulled with 2007 GMC sierra classic 2500hd 4x4. ky lake :nutkick :thumbsup :eviltaunt
GXPWeasel
Re: kenwood marine radio
#2 Post by GXPWeasel » Wed May 28, 2014 1:51 pm
That sucks.
How did it get wet? Does it not install into a normal location like most radios, or was it out in the open?
MH Hawker
#3 Post by MH Hawker » Wed May 28, 2014 1:59 pm
I put mine in one of these and haven't had a problem since.
http://www.bossaudio.com/marine/marine- ... dio-mrc10/
#4 Post by curtiscapk » Wed May 28, 2014 2:17 pm
yep that's the one I got!
chopper6358
#5 Post by chopper6358 » Wed May 28, 2014 5:57 pm
it was mounted in the normal spot with the weather proof cover on it. :x there is a depth finder/gps mounted on the dash above it. guess water got in around wires and screw holes
Hawk_308
#6 Post by Hawk_308 » Wed May 28, 2014 8:14 pm
Kenwood used to be good stuff but I know in the ham radio world they have became really hit or miss as far as radios go. They will release a wiz bang radio and then replace it with one that sucks within a couple of years then keep the sucky one for 6 or 7 years in its line up
robster
#7 Post by robster » Thu May 29, 2014 5:29 am
The non-marine radio's don't like any kind of moisture,the circuit boards rust easily and crap out. The marine grade radios have coated circuited boards that do better in moist environments.
Comstocker
#8 Post by Comstocker » Thu May 29, 2014 6:58 am
If you read the fine print in the Kenwood warranty it specifically states that it is NOT water-proof. They coat the circuit boards and that's it, they don't waterproof the chassis. There are very few radios that are fully water-proof, especially under $200!
I'm installing a new Kenwood in my pontoon rebuild and it will have a plastic cover over it so water can't run down into the chassis from above. I'll try to remember to take pics of it mounted in the console.
Ken McMillan
Mayor of 100' of Paradise on Comstock Lake
