Does vinyl paint work?
Posted: Tue Jun 03, 2014 6:28 am
by wijames
I just purchased a boat that's been sitting for quite a while and had a lot of mold and mildue on the white seats. I was able to get most of it off but not all. The seats are still in good shape and I was wondering if anyone had any experience with any of the vinyl paints and if so, how they worked for them.
Re: Does vinyl paint work?
Posted: Tue Jun 03, 2014 6:40 am
by VacationLand
I've used a product by the name of SEM on a car to spruce up the vinyl door panels and interior trim. It worked very well for those. I don't know how it would hold up on seats with all of the usage they would get though...
Posted: Tue Jun 03, 2014 9:48 am
by jrolin1
I would try fairly strong diluted bleach before using the vinyl paint. I start with about 20% bleach diluted with water and let the sun do some work on it. Just avoid the threads/seams as much as possible. Move up the strength if needed. My seats are on the 10th season doing this with no problem and they still look good. I use 303 after getting them clean to protect them from the sun. I used the vinyl paint before on an older boat and on a waverunner and it works ok but wears off and feels different.
Posted: Tue Jun 03, 2014 1:21 pm
by wijames
jrolin1 wrote:I would try fairly strong diluted bleach before using the vinyl paint. I start with about 20% bleach diluted with water and let the sun do some work on it. Just avoid the threads/seams as much as possible. Move up the strength if needed. My seats are on the 10th season doing this with no problem and they still look good. I use 303 after getting them clean to protect them from the sun. I used the vinyl paint before on an older boat and on a waverunner and it works ok but wears off and feels different.
Thanks. I really wouldn't be using it on the seats but on the runners and side consoles around the seats so maybe I'll give it a shot but I'll try the bleach first.
Posted: Tue Jun 03, 2014 4:03 pm
by babock
Be EXTREMELY careful with bleach. Get ANY on the thread and your seams will be ripping apart in short order.
Posted: Tue Jun 03, 2014 4:12 pm
Upholsterers use vinyl stains all the time. You can completely change the color too.
If I was using it, it'd be a last resort--prior to having to get new upholstery.
