Can you have dual batteries without a switch
Posted: Fri Jun 06, 2014 8:54 pm
Good evening folks! I am new here. My name is Neil and I am from Southeastern Kentucky. I am not a new boat owner but am definitely new to the pontoon world. My wife and I just bought our first pontoon two weeks ago and we couldn't be happier. It is a 2009 G3 Suncatcher 188F with 50hp Yamaha 2 stroke engine. It's small, but we like it. It also has a Minn Kota trolling motor with the factory plug up front to connect it to power. We have it parked at a local lake in a covered slip. Our slip has power available so I decided I wanted to install a battery charger. My boat has dual batteries already.
I purchased a Guest 2611A charger. Here is where it gets a bit fuzzy for me. Like I said, my boat already has dual batteries. I have not yet found a switch of any kind for switching between the batteries. The only switch is a master switch on the dash which turns everything on the boat off with the exception of the motor. It will start and run just fine with that master switch turned off (found that out by accident it seems). Things like the radio and lights will not work with the switch off.
One battery is in a battery box like the ones found at Wal-Mart. The other is out in the open in what seems is the factory tray with a nylon strap buckled across it. The battery in the box has multiple wires hooked to it that run down and thru a grommet into the bottom of the boat. It is quite obvious that this battery has wires connected to it that run back out and connect to the motor (same black wire with white stripe). Like I said, there are many wires on this battery.
The other battery that is not in the box only has one heavy gauge wire running from it on each post. I did not have an electrical meter with me to test continuity between the leads on the battery. I know that's ultimately how I will have to test it to determine if it is a 24 volt system.
Each battery has what appears to be a resettable circuit breaker on one of the wires coming off it. They have 24 vdc written on the side. I did not read what amperage they were.
So, that leads to my questions. Did these boats come from the factory as 24 volt systems? Is that normal or would it be something the previous owner had installed? My Guest charger is capable of charging two batteries in a 24 volt system so I should be OK there. Will the alternator on the boat charge both batteries?
Any tips on where to mount the charger? I looked all around tonight and really can't find a good place to mount it.
Thanks so much for all your help!
Neil
Neil
