Is this normal?
Posted: Sat Jun 28, 2014 7:12 am
by Clearwater262
Is oil coming out of the "vent" screw normal? Also, what is the soft rubber piece hanging off the motor in picture 3? Thanks
Re: Is this normal?
Posted: Sat Jun 28, 2014 7:13 am
by Clearwater262
Looks like the soft rubber piece is in picture #1. Sorry for the big pics, I thought downsizing them by 25% would be enough.
Re: Is this normal?
Posted: Sat Jun 28, 2014 7:21 am
by HandymanHerb
480 x 640 works good on the forum
Re: Is this normal?
Posted: Sat Jun 28, 2014 8:19 am
by jimrs
With the screw removed or real loose oil should come out of the vent if the lower unit is full. If it's tight then you might be missing a gasket under the screw head. Not only will it loose oil but let water in. The piece your talking about is a hook up for a speedo meter. I resized your pictures.
Re: Is this normal?
Posted: Sat Jun 28, 2014 9:48 am
by lakerunner
I think Merc's use O rings to seal lower unit screws
Re: Is this normal?
Posted: Sat Jun 28, 2014 12:24 pm
by BoatCop
Mercury uses fiber washers for their drain and vent screws.
If it's leaking, there could be a few causes:
Washer missing
Washer old (dried up and brittle)
Washer split/broken
Washer doubled up (previous service didn't remove old washer and put new one on top of it)
Re: Is this normal?
Posted: Sat Jun 28, 2014 5:04 pm
by Bryden24shp
BoatCop wrote:Mercury uses fiber washers for their drain and vent screws.
Washer missing
Washer split/broken
#2.... Yep!
Re: Is this normal?
Posted: Sun Jun 29, 2014 12:30 pm
by babock
You need to replace those every time you change your gear lube.
