Those with 24V trolling motors
BillieS
#1 Post by BillieS » Tue Jul 15, 2014 8:49 am
How are you monitoring your batteries? Across both batteries to read 24V, or each battery seperatly to read 12V using two displays? I want to monitor the trolling motor batteries but am looking at what everyone else seems to be using/doing.
2008 SunTracker Fishing Barge signature series 21/60HP Bigfoot 4 Stroke EFI, 85# Thrust Minn Kota Terrova Trolling motor W/Remote control and foot pedal
cuda67bnl
Re: Those with 24V trolling motors
#2 Post by cuda67bnl » Tue Jul 15, 2014 10:45 am
I don't monitor mine. They're on a bank charger that gets plugged in once off the water so they're always fresh when I take the boat out. My trolling motor has a button you can push that shows state of charge, but I never check it.......
#3 Post by HandymanHerb » Tue Jul 15, 2014 10:48 am
If your using them together use the 24 volt meter, then use a duel bank charger to charge them the same and not over charge
BillieS
#4 Post by BillieS » Tue Jul 15, 2014 11:40 am
I have them on a bank charger, Guest 2 Bank, at 24V. I did not know if there was any advantage to monitoring them seperatly. My trolling motor, Minn Kota Terrova 80, has an indicator on it but is a PITA to use. I was thinking on the LED readout.
PlaynDoc
#5 Post by PlaynDoc » Tue Jul 15, 2014 3:19 pm
BillieS wrote:I have them on a bank charger, Guest 2 Bank, at 24V. I did not know if there was any advantage to monitoring them seperatly. My trolling motor, Minn Kota Terrova 80, has an indicator on it but is a PITA to use. I was thinking on the LED readout.
I too, have a minn kota terrova 80, which have indicator lights...
charged with dual bank Minn Kota charger...
i monitor the batteries by.... 'if the motor isn't very strong.... mmmm... i guess they are dead now' ??
C_M_25
#6 Post by C_M_25 » Tue Jul 15, 2014 7:34 pm
I'm ignorant in the ways of bank chargers. What are those, and how do they work? Do you wire them up to the generator on the boat?
2014 Sweetwater 2086SW
90 Hp Yamaha 4-stroke
BillieS
#7 Post by BillieS » Wed Jul 16, 2014 4:19 am
Thanks Handyman! I think that is what I will do. Then if any indications show less than 24V i will check each battery individually and load test. I just replaced both batteries and want to get the best I can from them without killing one or the other.
#8 Post by HandymanHerb » Wed Jul 16, 2014 5:12 am
C_M_25 wrote:I'm ignorant in the ways of bank chargers. What are those, and how do they work? Do you wire them up to the generator on the boat?
You plug them in when you get back to dock or home and they stay hooked up, then when you plug it in it decides if it needs charged and then make sure both batteries are fully charged, even hooked up 24 v it still charges each battery at 12 v separately, that way if your using one battery for 12 v for the radio or other things on the boat, then it will charge the low battery but not the one not used to make them last longer
