Well, we just purchased our 2014 Harris Flotebote 200 Cruiser tritoon with a 115hp mercury 4 stroke efi. We've practically lived on it all summer. The family is happy with every aspect of the boat.
Of course now I want to tinker!
I am running 31-33mph depending on load and water conditions.
prop= Mercury Spitfire 13.8x13P
RPM=6800 trimmed
Thoughts?
Compare your Prop setup
2014 HF Cruiser 200 tritoon, performance package PLUS, 115hp efi Merc 4 stroke
top speed = 33.5mph GPS
Mercury Spitfire 13.8x13 prop
Re: Compare your Prop setup
I know someone smarter than me will add their input but that seems to be above the recommended RPMs for that engine...
http://www.mercurymarine.com/engines/ou ... 5/?model=2
Other places cite a little different WOT range:
115 EFI FourStroke Specifications
HP @ Prop: 115
kW @ Prop: 86
Max RPM (WOT): 5800-6400
HP @ Prop: 115
kW @ Prop: 86
That was a concern of mine. When does the motor hit a rev limiter?
It should hit the limiter before 6800. I would check the setting and connections on the tach to make sure it's correct. 33 mph for your setup sounds pretty good though.
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
