Moving the helm seat back for comfort
Bugsbunnyboater
#1 Post by Bugsbunnyboater » Sun Jul 27, 2014 10:20 pm
Has anybody had to move their helm seat back for comfort. On my sweetwater it seems really close to the
Console I am a bit over six feet tall. It's funny I had a guy doing work on it and he asked do you want me to move the seat back he is over six feet too.
Am I right to assume the seats are through bolted to the deck.
rancherlee
Re: Moving the helm seat back for comfort
#2 Post by rancherlee » Mon Jul 28, 2014 4:00 am
Does your seat have a slider? If not it may be as simple as finding a slider that fits your post. The usually give 2.5" movement, 5" total, either way. Otherwise just unbolt it and move the base back a few inches IF you have access to the nuts under the flooring.
NonHyphenAmerican
#3 Post by NonHyphenAmerican » Mon Jul 28, 2014 5:33 am
:2cents
rancherlee wrote:Does your seat have a slider? If not it may be as simple as finding a slider that fits your post. The usually give 2.5" movement, 5" total, either way. Otherwise just unbolt it and move the base back a few inches IF you have access to the nuts under the flooring.
This! :2cents
rockhound
#4 Post by rockhound » Mon Jul 28, 2014 6:37 am
The slider should be an easy retrofit
Obama: finally gone, MAGA
Bugsbunnyboater
#5 Post by Bugsbunnyboater » Tue Jul 29, 2014 12:22 am
There is no slider on the seat.. And I have the boat in a wet slip so I can't get to the seat bolts . Yuck...
cwag911
#6 Post by cwag911 » Tue Jul 29, 2014 6:30 am
Does your seat swivel? If it does, you should be able to add the slider.
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
