I think I know what I need to do...
Posted: Mon Jul 28, 2014 5:52 am
but would like a little confirmation from people with more experience.
I have a power sense battery box (has an LED meter on it to tell me how charged my battery is before we go out) connected to the battery. The box then has connectors on the outside of it, for the power leads to the engine starter and accessories. http://www.overtons.com/modperl/product ... on&i=25600
Had the boat out yesterday, ran fine - we went out, and anchored in a quiet cove; spent the day hanging out. While we were out there, I unscrewed the power cables at the battery box connection, just long enough to add a connector cable for a solar maintainer (a smart one that won't overcharge the battery, since where our boat is parked, there is no power for a trickle charger).
Tightened everything back down; we had the stereo playing and power to all accessories. When we got ready to leave... "click". Engine wouldn't spin over. So I went back, checked my connections - everything was tight, wing nuts were good. Tried it again... "click" - no starter. So - I loosened the wing nuts slightly, and moved the cables - there was still pressure on the connectors, but loose enough I could move them - then tightened everything back down, hit the starter and it spun over just fine.
I had this happen a few weeks back when I was doing some work on the boat in the driveway - trim unit stopped responding - had power to starter, though.... Same story - loosened the connector, moved the cables slightly, tightened it back down and all was fine.
This boat sat for two years, in the water, no use. I was looking at the connectors last night and they are not shiny silver, but dark grey - they seem to be very oxidized (not corroded - just turned dark). Thinking the best thing to do at this point is to take some very fine sandpaper or emery cloth, clean the oxidation off of them, and then put a light coating of die-electric grease on them before I tighten everything back down. If I get the connectors cleaned, thinking it should solve the problem and the grease will at least significantly reduce the oxidation returning, especially since the boat is now being used regularly. Worst thing in the world for electrical connections is for them to sit idle, outside.
Thoughts or recommendations? Is my train of thought logical and is it running on the right track?
Thanks, guys - much appreciated.
Ken
Ken
