Trailer Bunk Question
C_M_25
#1 Post by C_M_25 » Fri Aug 01, 2014 3:25 pm
Hey guys. So I picked up my boat today to get it ready for tomorrow. When I was doing the walk around, I noticed the bunks on one side are shifted forward a bit which caused the brackets that are bolted to the trailer to rotate. On the other side, everything is still straight. There seems to be a gap, maybe 3/16'ths of an inch between the U-bolt and the frame. Is that why the bunk slid forward on the one side? Seems like I could move the bunk back to where it is supposed to be when I get the boat off the trailer tomorrow, but do you think I can keep this from happening again just by tightening the nuts down a little bit? I think they may have backed off enough. Any chance that this could shear those bolts if it happens again?
That would be a bad day...
2014 Sweetwater 2086SW
90 Hp Yamaha 4-stroke
dunny961
Re: Trailer Bunk Question
#2 Post by dunny961 » Fri Aug 01, 2014 3:57 pm
Looks like that side took a blow while loading the boat. Just loosen the u bolts, readjust, and tighten back down. The helpers on my trailer get shifted just about everytime I load the toon. I've thought about bracing them up but I figure this way they're not gonna get bent if they move a little. So, just keep an eye on them from time to time.
90 Mercury Fourstroke
C_M_25
#3 Post by C_M_25 » Fri Aug 01, 2014 4:00 pm
dunny961 wrote:Looks like that side took a blow while loading the boat. Just loosen the u bolts, readjust, and tighten back down. The helpers on my trailer get shifted just about everytime I load the toon. I've thought about bracing them up but I figure this way they're not gonna get bent if they move a little. So, just keep an eye on them from time to time.
You think that is possible to do with the boat still on?
C_M_25
#4 Post by C_M_25 » Fri Aug 01, 2014 5:16 pm
Oh, and those are actually the brackets for the bunks. All the brackets on the starboard side are rotated like that. I'll just straighten it out. My guess is I came in a little cock-eyed and the boat didn't make it perfectly straight. It was dark too at the time whcih didn't help.
old jim
#5 Post by old jim » Fri Aug 01, 2014 5:53 pm
Maybe another set of bolts on each bracket? old jim
#6 Post by margaritaman » Fri Aug 01, 2014 6:36 pm
old jim wrote:Maybe another set of bolts on each bracket? old jim
Another set of U bolts on each bracket spread a few inches apart would make it impossible to turn like that.
#7 Post by lakerunner » Sat Aug 02, 2014 7:50 am
And use nylon insert SS lock nuts
tadams
#8 Post by tadams » Sat Aug 02, 2014 9:56 pm
Exactly what I was thinking
You don't stop playin because you get old,
You get old because you stop playin!
