40 hp mercury issues
Dorsey75
#1 Post by Dorsey75 » Thu Aug 07, 2014 10:48 pm
Hey guys I got a problem with my little mercury 40. It's on a 21' 2002 tracker, it performs great, runs fine, goes all day. Problem is when we beach it for a couple hours and raise the motor up it looses its prime and won't start right up. I pump the bulb and choke it and fast idle and eventually it starts back up and runs fine. We did kind of a test this week and left the motor trimmed all the way down for five days started right up no hesitation, trimmed it up and let it set for two hours and lost prime ( I assume) Re primed with bulb, fast idle and it started. I'm afraid I'm going to drain my battery and be stranded some evening on the beach. I've had the boat three years and this is a recent development. I thought the second fuel filter was maybe leaking out the cap while trimmed up but I replaced it with a new one today and same problem persists. Thinking about taking it to the shop on Monday but I wanted to check with you guys and maybe get some input. Thanks
BillieS
Re: 40 hp mercury issues
#2 Post by BillieS » Fri Aug 08, 2014 4:18 am
I think I would start looking for loose connections, hose fittings (maybe the one that goes into the engine). It sounds like your loosing prime when tilting the engine.
2008 SunTracker Fishing Barge signature series 21/60HP Bigfoot 4 Stroke EFI, 85# Thrust Minn Kota Terrova Trolling motor W/Remote control and foot pedal
teecro
#3 Post by teecro » Fri Aug 08, 2014 4:20 am
Isn't there a check valve in the primer bulb? :coffee
LocoCoco
#4 Post by LocoCoco » Mon Aug 11, 2014 6:17 am
^ Like he said, bad primer bulb so too much fuel drains back into the tank?
Have you noticed fuel leaking out into the water while tilted? Perhaps a carb float is stuck and the bowl is draining when tilted?
LC.
