trailer dilemma
Posted: Thu Aug 14, 2014 7:21 pm
Ok, so if you read my post about my billet aluminum hitch you'll know how this all started
I decided to get a fixed drop hitch (steel) and went out to my boat to measure the drop and get 'the right one'. I have a 2011 bear trailer. Bear supplies the trailers for Landau, so I thought that would be best.
Here's what I found.
Using a 4' level I adjusted the tongue jack to make the trailer level at the wheels. Measuring from the ground to the bottom of the frame, I got a consistent 14" in front and behind the dual axle setup. Moving to the tongue, expecting a similar measurement, I found the tongue of the trailer measuring 22" to the bottom of the frame. a WHOPPING 8" difference!!! WHISKEY TANGO FOXTROT!!!
Does anyone else have that much difference between their tongue and the frame at the axle?
It was getting dark, so I couldn't see much detail, but I don't 'see' any evidence of a nasty bend in the trailer, but by my way of thinking this is not right.
What do you think?
b
What do you think?
b
