How to determine what prop I need?
I recently had a strange thing happen. My 2000 20 foot tri-toon Sylvan with a 2000 BF90 on it has been running at 5900 RPM and doing around 25 MPH. The prop was looking a little knarley so I had it rebuilt. Now I can only get 5200 RPM out of it and 20 MPH. I tried a second prop and got the same result. The prop I have now is a 3 13.5 x 15R, does anyone know what I should be using? I've looked at half a dozen prop calculators on the web and every one of them give me a different answer.
(old) 2000 Sylvan 20' Tritoon
Re: How to determine what prop I need?
Prop calculators are useless for a pontoon. Common pitches are 7,9.11,13 and on some of the newer tri toons a 15.
I would guess a 13
I would guess a 13
is it a fuel injected motor? have you checked your fuel filters? The motor could be running out of fuel causing the lack of RPM. Just an idea...
2014 Sylvan Signature 8523 LZ
2014 Yamaha F200 2.8l
Iowa
Iowa
That would be a real coincidence having the fuel filter go at exactly the same time I had the prop done. I'm just talking about a week between when it was getting 5900RPM, having the prop redone and then getting 5200 RPM so I doubt if that is it but I'll check.rdeterman wrote:is it a fuel injected motor? have you checked your fuel filters? The motor could be running out of fuel causing the lack of RPM. Just an idea...
I'll see if the prop shop has a 13 I can try before buying one.MH Hawker wrote:Prop calculators are useless for a pontoon. Common pitches are 7,9.11,13 and on some of the newer tri toons a 15.
I would guess a 13
I suspect the prop shop rebuilt it using the wrong set of blocks. I would send it back to them and tell them where you were performance wise, before and after the rebuild. They would probably recheck it and fix it for free.
I was guessing the shop added some extra cup to it
