Newbie wants to clean logs on toon.
Hi all, new to toons. I have a 2001 Crest Superfish 22 that has been in the water 11 months and has a good algae growth on it. I have read all sorts of methods and would like some input. I would rather not use any acid type products because I don't want to damage my logs. I personally don't want to spend weeks polishing them either. I have a pressure washer and was thinking of trying it first with some detergent. The toon is currently residing in Dale Hollow Lake. Any and all suggestions are welcome. BTW I did search and read some previous discussions. Thanks Mac
Retired.
2001 22' Crest Superfish, 90hp Merc
sitting in a slip on Dale Hollow Lake
Re: Newbie wants to clean logs on toon.
I just did mine. Cleaning the underside of the strakes without being waterboarded was a skill learned.
viewtopic.php?f=2&t=20783
Welcome to the club.
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
Ted & Emily
2019 Yamaha 150 HP
Soonertoon
1. Pressure wash
2. Toon Brite- full strength
3. Pressure wash
4. Toon Brite-full strength
5. Pressure wash
6. Shark hide
Do not deviate from this procedure above and you will end up with a superb result. It will take you an afternoon or two but it will be worth it when u are done
3. Pressure wash
5. Pressure wash
6. Shark hide
Broken Arrow Ok
2014 G3 Suncatcher
115 Yamaha 4 stroke
2014 G3 Suncatcher
115 Yamaha 4 stroke
Ok so the sharkhide is a polish, do you use an orbital polisher? Thanks for all the help guys.
Retired.
Sharkhide is a coating to keep logs from staining. Apply after logs are clean
Well I had thought that also, but searched yesterday online and found sharkhide polish and wanted to be sure. Also do you know if the toon brite will turn the aluminum white and can it hurt the toons? I have read a lot of info that says any acid can cause pits and they grow. I would rather have an ugly toon than a sunken toon. Thanks
Retired.
Here's a link to the thread with pics of my log cleaning.
viewtopic.php?f=2&t=20656
I use Napa Aluminum Brightener and yes it does turn the logs white. Last year I just used the Napa stuff and left the logs white (still better than they started out). I didn't want to go to the hassle of polishing the logs. But this year, I went the extra step and polished the logs after the Napa stuff and wow, what a difference. Hopefully this first time was my hardest -- I'm hoping each year from now on won't take as long to polish them. But after seeing how shiny I can make our 2003 logs, I'm willing to put the extra work into the project.
Thanks Steve, the more I read the more I am realizing that I will need to polish the logs if I want them to look good. I guess I am looking for the miracle cure that you spray on and rinse off then go to the lake. Yeah right!!
Retired.
No reason to attempt to use Sharkhide unless they're polished.
I see where Harbor Freight's selling a dual action polisher/sander cheap this month. Go to the auto paint store and buy a wool bonnet, and you're in the aluminum polishing business. Then go to Advance and get yourself some White Diamond metal polish.
Polishing the outsides of my toons, three nose cones and the tails of my toons just takes over an hour. It's just not that hard of work.
Now getting all the black aluminum oxide off the toons good enough to use Sharkhide is a back breaking experience. I've never got'em clean enough to Sharkhide. I just polish my boat the first of June every year.
