electric binimi top
crookedlaker
electric binimi top
#1 Post by crookedlaker » Thu May 21, 2015 1:01 pm
Well got all other chores done
new lift and canopy installed
under sheeted bottom of boat
led lights installed and now to install electric binimi top
if anyone has installed one, how did you run the wires from the port actuator to the drivers console
i was thinking of running the wires thru the square binimi tubes,it looks like they provided enough wire
and the tubes should protect it. any ideas anyone
Mike
2017 Harris Sunliner 200
Tri-toon P+ Package
2017 Mercury 150 4 stroke
Re: electric binimi top
#2 Post by curtiscapk » Thu May 21, 2015 2:09 pm
That's how the anchor light is wired. I would do the same. Did it come with an anchor light or are you putting your old one on?
Gonefishing
#3 Post by Gonefishing » Thu May 21, 2015 3:38 pm
That is how I did mine. Ran all the wires through the tubing. Just make sure you leave enough slack so when the top goes up you don't have a problem. If you have the anchor light you can do the same thing run wires through the tubes. Good luck and enjoy. I love mine did yours come with a remote. Love the remote can walk up to boat while docked and rais the top works great
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
crookedlaker
#4 Post by crookedlaker » Fri May 22, 2015 5:13 am
I am using my light from my old canopy
yes i got the remote
The light wire plugs into a socket on back of one of the seats and then runs up in the rear tube on the the starboard side
it looks like i have to run the wire out of the actuator and drill a small hole in the bottom of the tube with a small loop to allow the top to articulate up.
i thought i could run thru the actuator into the bottom tube with the angle cut but it looks like it would get pinched so i will probably run a small loop from the actuator to the tube on the other side also.
Bought from Pontoon Stuff
$895.00 less 10% discount
free shipping and free remote upgrade
great deal
looks like very good quality
hope to have up and running this weekend
Mike
Tri-toon P+ Package
ToonGuy
#5 Post by ToonGuy » Fri May 22, 2015 5:30 am
That's exactly how I wired mine as well.
