Fishfinder swap
Will
Fishfinder swap
#1 Post by Will » Fri Jun 19, 2015 7:05 am
I have a Humminbird 586c fishfinder which cuts out after we leave our dock and doesn't turn back on it was suggested to me that it was probably was the circuit board that was gone on it and sending back to Himminbird for repairs is not worth it. So my question is can I buy another Humminbird in the 500 series and use the same wiring of my 586c
2010 Berkshire 200 CL with a 50hp bf 4 stroke Merc
2006 Sea Ray 185 Sport
"You can go through life half-heartedly and still succeed"
Scott1
Re: Fishfinder swap
#2 Post by Scott1 » Fri Jun 19, 2015 9:28 am
Will wrote:I have a Humminbird 586c fishfinder which cuts out after we leave our dock and doesn't turn back on it was suggested to me that it was probably was the circuit board that was gone on it and sending back to Himminbird for repairs is not worth it. So my question is can I buy another Humminbird in the 500 series and use the same wiring of my 586c
When you say cut out, do you mean it loses power? If so then yes it is something with the unit or wiring. If it loses readings, it is your transducer.
Also, if you replace it you need to find out if your old transducer will work with the new unit. Many newer units have better transducers that give it better readings and readouts, 3D, etc. If so, you need to purchase the new transducer and run the cable new. Not sure about the wiring, I don't see why not.
2014 Bennington 2375 RCW with Verado 250 Pro and Simon Motorsports ECM upgrade to 325 HP
Tri Toon with ESP package
C_M_25
Re: Fishfinder swap
#3 Post by C_M_25 » Fri Jun 19, 2015 9:37 am
If you are going to upgrade the unit, you might as well upgrade the transducer. It is a fairly simple job so long as you don't have underskinning. It also makes things easier if you get the same model because then you can use the same mounting bracket for the transducer.
2014 Sweetwater 2086SW
90 Hp Yamaha 4-stroke
