Later, the boat wouldn't start even with jumper cables. The two lights on the dash came on but got absolute silence from the motor. No starter engagement noise and no clicking. Had to get towed home in a storm.
I pulled the cowling and checked the three fuses on the port side. Then I checked the 90 amp main fuse. All buzzed good with an ohm meter. When I finished checking the fuses, the boat cranked and ran. So I thought maybe pulling and reinstalling the fuses either re-seated a fuse that wasn't making good contact or cleared some error from some computer memory.
Put it on a charger overnight because the battery was still not fully charged. But it wouldn't crank Sunday morning. The battery was suspect anyway, so I got a new one. Boat still won't crank.
I know I need to see if I have juice at the starter when the key is turned to the start position, but I had trouble getting the inner cover off of the top of the motor. Need to remove it to get access to the starter. A bastard captive nuts just spins and won't release the bolt. Ran out of time yesterday so had to quit.
I'm thinking the problem is either the neutral lock out mechanism or the kill switch. I played with both and am sure it was in neutral and the kill switch connector was attached. Anyone have any other thoughts or have a procedure to test the neutral lock out or kill switch?
