Here are the symptoms:
- At full throttle I only get about 1000 RPM instead of 4000-5000
at random RPMs the overheat buzzer in the throttle box stars buzzing
My first though was we forgot to mix oil into gas on the last tank full, but we're 90% sure that's not the case. If these symptoms describe EXACTLY what would happen if the oil mix were way to low, we'll assume we're wrong and undermixed or forgot to mix.
Any other ideas?
At a slow crawl, just above idle, everything seems to work correctly.
I am planning to take this into the shop but I want to do any troubleshooting I can before turning it over to them.
(I am aware of the Force motor reputations. No need to revisit that)
