Trim issue
jadeboy
Trim issue
#1 Post by jadeboy » Mon Sep 14, 2015 8:04 am
Have a isssue that i can only trim up about 1/4 on trim gage at speed slow down and can trim all the way up any ideas i did just have a prop fix but it looks really good.
garygve
Re: Trim issue
#2 Post by garygve » Mon Sep 14, 2015 8:38 am
Most newer engines don't allow you to trim too high when at higher rpms and under load, its a safety thing and also so you don't starve the engine of water.
150 Mercury 4-stroke
jadeboy
Re: Trim issue
#3 Post by jadeboy » Mon Sep 14, 2015 9:05 am
Is there a high speed trim adjustment because i could get it to suck air before something changed. It's on 2015 Mec. 115
garygve
Re: Trim issue
#4 Post by garygve » Mon Sep 14, 2015 4:41 pm
I think you might have to have a Mercury dealer adjust it with their Mercury engine analyzer, my 2014 150HP has to be adjusted for the max trim that way but I'm not sure about the 115. I don't know what they can all adjust on the trim you will have to call a dealer and find out.
