Fill befoe stablizing?
Posted: Sat Oct 03, 2015 12:47 pm
Should the gas tank be filled before stabilizing for the winter storage or leave space in the tank?
Open and Honest Pontoon Boat Discussion
https://pontoonforums.com/
The fuller the tank the less air space you leave. Air space increases the chance for the fuel to interact with the air causing oxidation, also the increased air space increases the chance for condensation too...GGALVIN wrote:Should the gas tank be filled before stabilizing for the winter storage or leave space in the tank?
Gonefishing wrote:When I store mine for winter I add the stablizer fill the tank and run the motor with muffins on just to run stablizeres fuel through the motor. But I also always add a stable riser to my fuel during the season also while in use.
Bagels will take out T-stats, right now!lakerunner wrote:Gonefishing wrote:When I store mine for winter I add the stablizer fill the tank and run the motor with muffins on just to run stablizeres fuel through the motor. But I also always add a stable riser to my fuel during the season also while in use.
I think muffins would clog cooling ports
Bryden24shp wrote:Bagels will take out T-stats, right now!lakerunner wrote:Gonefishing wrote:When I store mine for winter I add the stablizer fill the tank and run the motor with muffins on just to run stablizeres fuel through the motor. But I also always add a stable riser to my fuel during the season also while in use.
I agree LOL not good to use muffins. Hope. He know what I did mean. Dam keyboard
