Can I use these with 24v?
photonfanatic
#1 Post by photonfanatic » Wed Apr 20, 2016 4:10 pm
http://www.amazon.com/STVMotorsports%C2 ... ge_o00_s00
It says they are 12v, 20a rated switches. But, I would like to use it with 24v instead of 12v. Any reason I shouldn't do that? Don't want to start a fire or anything. I'll only be pulling about 4a through them.
crspang
Re: Can I use these with 24v?
#2 Post by crspang » Wed Apr 20, 2016 4:28 pm
The switch's contact will open and close and conduct the 24v but the LED backlight probably won't work since it is only rated for 12v.
teecro
#3 Post by teecro » Wed Apr 20, 2016 5:07 pm
crspang wrote:The switch's contact will open and close and conduct the 24v but the LED backlight probably won't work since it is only rated for 12v.
That's what I was going to say too... The Switch contacts will be fine with the voltage but the LED's may NOT like being fed twice their normal voltage...
