Stainless vs aluminum prop?
Animal House
Engine: 2014 Verado 200 HP
Vessel: Premier Tritoon 24'
Current prop: Black Diamond 16 x 16 3 blade
Top RPM: 6,200
Top speed: 34 MPH (3 adults/47 gal fuel)
Stainless or aluminum?
3 or 4 blade?
Top RPM: 6,200
3 or 4 blade?
pond tuuunes
Re: Stainless vs aluminum prop?
SS, 4 blade
You're running a little slow for the engine. But rpm's are about right.
Prop? Stainless Mercury Enertia prop is the standard of the industry for your boat. It's also available every 1" pitch--which is great.
Personally on a pontoon I like an aluminum prop. It will destroy its self rather than your prop shaft. If you want total efficiency get a bass boat IMHO
I used to use aluminum props on my inboard outboard ski boat, and I'd go through a prop a year--crunching them in the rocks. Fortunately, Jim's Prop Shop is owned by a cousin and he fixed them cheap.
When I got a new boat, I switched to a stainless propeller. In 11 years, I scarcely scratched that propeller.
I just prefer a stainless prop, especially when getting above 115 hp.
Stainless all the way, 3 blade all the way. Aluminum will work, but you will get less slip and more grip with the stainless. I used to run Aluminum on by ski boat because I was afraid of ruining my lower unit if I hit something. I started with Aluminum on my Pontoon, but went to stainless and performance was much better. The Merc props have the flo torque hubs that break away. I have hit a rock and a log with my prop, no damage to speak off, Aluminum prop would have been destroyed.
2014 Bennington 2375 RCW with Verado 250 Pro and Simon Motorsports ECM upgrade to 325 HP
Tri Toon with ESP package
- rancherlee
Stainless all the way, especially on ANY engine over 115hp IMO. Stick with a LARGE diameter 3 blade unless you can't find a 3 blade that gets good hookup for your conditions. That said, 34mph DOES sound a bit slow for your combo and a stainless would be good for 2-3mph on your setup but that's not enough to make up for the 6-7mph your missing UNLESS its just a straight up tritoon with no strakes instead of a PTX or Straked tritoon. I'd expect top speed north of 40mph with a 200 on a straked or PTX Premier. I took a Used 24' Premier Castaway straked tritoon for a test ride with a 140 Suzuki on the back and seen 36mph GPS with Owner, my Wife, and Me aboard.
Edit. I just ran your numbers and it looks like you are seeing over 30% slip!, not good on a Tritoon, should be easy to get under 15% slip with good prop. I'd stick with 15 or 16 pitch props for testing.
- Spoiledrotten
With my first aluminum prop, I hit a below surface log, and destroyed my aluminum prop and bent the prop shaft, so it can still happen with aluminum. I now have a SS 4 blade.RcgTexas wrote:Personally on a pontoon I like an aluminum prop. It will destroy its self rather than your prop shaft. If you want total efficiency get a bass boat IMHO
[b][i]Randy and Kelly
Brandon, MS
2015 Bennington SXL 20
2015 Yamaha F90
TOONAFUN [/i][/b]
Brandon, MS
2015 Yamaha F90
TOONAFUN [/i][/b]
