Changing oil
Jake202
Changing oil
#1 Post by Jake202 » Sun May 29, 2016 9:43 am
Was wondering if anyone has ever changed the oil in their motor with it in the slip or is it a must to pull it out to be changed. I don't have a trailer and the guy who services my old motor gets $125 to pull it out of the water. Thanks
Re: Changing oil
#2 Post by Bamaman » Sun May 29, 2016 5:07 pm
You could always get the grandkid's little plastic swimming pool and float it under the lower unit==and let'er drain. It made a mess on my driveway yesterday with a regular drain pan.
I first drain my lower unit gear oil into a clean, dry pan as I'm looking for any metal shavings or water intrusion indicating any seal problems. Then I drain my motor oil into the same pan..
I have a manual oil pump that can be threaded in the dipstick tube down to the crankcase. Most dealers suck the oil out rather than drain the oil with gravity.
Aluminum Maiden
Re: Changing oil
#3 Post by Aluminum Maiden » Mon May 30, 2016 1:07 pm
My T60 has a hose going around the drain plug. I simply tip the motor all the way up and remove the drain plug. Then I clamp a larger hose over it and lower it all the way as it drains into an oil 5 gallon jug. Easy Peasy :D
I went drifting through capitols of tin
where men can't walk or freely talk
and sons turn their fathers in.
2008 Palm Beach Castmaster 200 Yamaha T60 18 mph upriver 22 mph downriver
2019 F150 EcoBeast 3.5 Supercrew 4x4 Max tow, Truetrac . Mods' a plenty
