Prop help for similar/same setup.....
Posted: Wed Jul 27, 2016 4:09 pm
by SamiGuy
2013 Sweetwater 2286. Strakes, Yamaha F115 four stroke swinging Ballistic 13 1/2 X17. Smooth, calm day, got some test data in. WOT 5200 RPM=31 MPH. Normal load, 2 adults, 22 gal fuel. On my third hub in as many weeks (spun yet another one today after test) and "appears" I am a bit over pitched. Will be cruising mostly with occasional tube pull and probably a few more adults. Will NOT be using a pressed hub prop again. Looking for Brand, size and pitch. What has been successful and where best to purchase.
Thanks in advance for all the assistance. It is sincerely appreciated.
Sami
Re: Prop help for similar/same setup.....
Posted: Thu Jul 28, 2016 5:47 am
by rancherlee
Yamaha does offer the stainless pontoon prop in a 15 pitch for that engine, same exact prop as the Turbo Pontoon 1 series. I had the 13 pitch on my 70hp 4 stroke suzuki and it was a good all around prop. 31mph @ 5200 = 25% slip and I think you could get it down to the 12-15% range and speed up to 33-34mph since you have strakes. The Solas Titan is another large 3 blade available for your engine and that's what I currently run on my DF140 in a 17 pitch, lots of grip and no issues with blowing out while aggressively pulling tubes (I have a tritoon though). I've never had an issue with a pressed hub spinning out so I really don't know why your having so many go bad
. Maybe your engine is too far below its powerband @ wot that it may be creating too much heat and cooking the rubber? I will say that I HAVE NOT had a square bore stainless prop on a midsize case engine that didn't rattle/chatter somewhat and its kinda of annoying at trolling speed.
Posted: Fri Jul 29, 2016 3:35 pm
by SamiGuy
Any other suggestions???
