Oil Leaking
rickpo
Oil Leaking
#1 Post by rickpo » Tue Apr 25, 2017 7:14 pm
I'll just jump right in. 2007 G3 Suncatcher with a 90hp 2 stroke.
I found oil leaking a few weeks ago. It was underneath the oil reservoir. It had pooled up and was leaking down the motor. The reservoir is not leaking. I pulled it off and pressure checked it.
There is also some sort of sensor(?) plugged into it. I see it wet around where the sensor is plugged into the reservoir. Seems like this is a common thing. Any one else experience this? The boat is 10 years old. Can this fix really be as simple as replacing the sensor? They are not cheap. Thanks
N.W. Arkansas
07 G3 Suncatcher 90 HP 2 stroke
taylorjm
Re: Oil Leaking
#2 Post by taylorjm » Wed Apr 26, 2017 4:11 pm
I can't offer much help except that I've read a lot about that motor and the oil reservoir, and the sensors and floats sticking in the reservoir.
rickpo
Re: Oil Leaking
#3 Post by rickpo » Wed Apr 26, 2017 5:57 pm
[quote="taylorjm"]I can't offer much help except that I've read a lot about that motor and the oil reservoir, and the sensors and floats sticking in the reservoir.[/quote]
I haven't had any problems at all, till this year...
Hopefully someone else will chime in.
N.W. Arkansas
