Not a "Maiden Voyage"...more of a "shakedown" cruise...
Posted: Sat Oct 07, 2017 8:19 am
Last month I had tried (spur of the moment) to take my project out for its maiden voyage and ended up having to tool around for about an hour on my "kicker" motor, because my main motor wouldn't start...I got back to "the yard" and began trying to figure out what went wrong. It took a few hours for me to notice that my automatic choke had somehow gotten out of adjustment....once I readjusted it, it fired right up...after running it from day to day for about a week, I pulled the plugs and they looked fine...
Fast forward to last tuesday, I re-launched.....had a hard time getting it to start, but once it started getting fuel, it would start up with just a "BUMP" of the starter switch...hmmm....after letting go of the launch dock, I backed out, turned around and headed towards open water...
After clearing the "no wake" buoys, I slowly eased the throttle forward and found myself cruising at about 15-17 mph and feeling smooth....I cruised around within about a half mile of the dock for about an hour....going from idle to full throttle and everywhere in between....it ran great for about an hour and a half and then, while at full throttle, it bogged down...I pulled the throttle back to about half and then it smoothed out....pushing the throttle forward again, it would briefly run fine, then bog down again....then surge...then bog...Feeling brave, I turned the key off...just "bumping" the starter, it would fire right up, but idle was rough...I started it back up and headed over to an area of the lake that had a smooth beach area and was protected from the wind....(I had a new set of plugs with me)...I pulled the plugs and the #1 plug was pretty black and pretty wet....#2 wasn't quite as black nor quite as wet. After changing the plugs, it fired right up & I headed back out. As soon as I got in deeper water, I pushed the throttle forward and it bogged down right off the bat...since I had put some sea foam in when I filled the tanks, and seeing how the boat has been sitting for at least 7 years that I know of, I kind of suspected I'd have some issues like this....right now, the plan is to order a service manual, carb and pump rebuild kits...replace all fuel lines, set timing and figure out and adjust the throttle/timing linkage...all in all, I had a pretty good day...I cruised around for about 7 hours, had a good lunch, didn't get stranded and best of all, my pontoons don't seep water....
