Need help identifying part.
Posted: Fri Jun 15, 2018 10:53 am
by mmuscaro
- 20180615_134415-1134x2016.jpg (354.97 KiB) Viewed 7720 times
This is on the right side of transom. You can see where that piece is cracked. Left one is already gone and this one went this weekend. I assume it has something to do with directing water flow?
Thanks in advance.
Re: Need help identifying part.
Posted: Thu Jun 28, 2018 9:07 am
by mmuscaro
Any thoughts?
Posted: Thu Jun 28, 2018 9:24 am
by FLOUNDERPOUNDER225
The pic is way too large, you can't get any perspective of the area in relation to the rest of the stern area. Take one not so close and I think it will be easier to identify by comparing the 2 pics.
Posted: Thu Jun 28, 2018 1:26 pm
by bansil
Agree back camera off, since it has adjustability I will guess....
A splash shield
what is interesting? the cut/grinded section that the splash shield is covering (notice "lip" left from cut off wheel?)
Need another picture
Posted: Fri Jul 06, 2018 4:31 am
by mmuscaro
Thank you. I will post new pictures tonight.
Posted: Fri Jul 06, 2018 11:43 am
by zoom650
Might help to know what make and model you're floating there.
I broke a cross member under the plywood deck. Took it to a metal fab shop and they couldn't weld it, the tear was so close to the deck. Instead, they bolted a brace in place and splinted/sistered it back together. If that's on your transom, maybe it needs some beefing up.
Posted: Wed Jul 18, 2018 12:23 pm
by BobG
There is no "right side of the transom", but there might be a "wrong side".
Is that the starboard side?
Probably the starboard rectilinear modulator excursion bracket.
