JB Weld on back of log
Posted: Sat Mar 14, 2020 6:15 pm
by mgarvie
On an earlier post I mentioned the dog ate the wiring on the back of my log. The wife says the dog stays and I have no where else to park the boat, so I adapt.
Would JB Weld hold 1/2 inch PVC to the back of my log? I figure I could run the wires to the transducer, wash down pump, and LED light strips through PCV pipe if I could attach it somehow.
Ideas?
Re: JB Weld on back of log
Posted: Sat Mar 14, 2020 8:44 pm
by jediger
Posted: Sun Mar 15, 2020 5:34 am
by mgarvie
I had some of that on top of the log around the wires. Found a shredded pile of it in my living room.
Posted: Sun Mar 15, 2020 9:59 am
by Steiner
Is a half dozen t posts and 100' of construction/snow fence out of the question? Would only cost about $60.
Posted: Sun Mar 15, 2020 12:47 pm
by bansil
Def. Wouldn't use jb weld, 3M 4200 should work for you, clean tube and pvc with scotchbrite and alcohol, small bead on pvc, install and lock in place with tape for 24/36 hrs, then run a small bead top and bottom, using a popsicle stick or cut up CC. Want another 24/36 ond you should be good, 3M 5200 is better BUT it takes a week to cure
