04 merc 115hp 4-stroke?
ttopmustanggt88
motor revs just fine when in neutral, but under load for the first 10 to 15 minutes of running it stutters like its being starved of fuel. i checked the primer bulb was tight and has no apparent leaks. do these motors have a water seperator that needs to be drained or replaced. maybe a fuel filter?? thanks for any help josh
TexasTooner
The merc has a fuel/water separator right next to where the spark plugs are. There is a clearish white tube that has a red floaty in it that is supposed to rise up in the tube when water is in it.
How many hours do you have on it. I would also put some fuel injector in it just in case
Best of luck
Andy
Best of luck
Andy
Captain StarLord of the vessel Stargazer
Crest 25’ Tri-toon
Suzuki 175 4-Stroke
F150 Platinum 4x4
Boerne Texas
Crest 25’ Tri-toon
Suzuki 175 4-Stroke
F150 Platinum 4x4
Boerne Texas
ttopmustanggt88
