sweetwater log specs?
i'm looking at the sw2086 and i can't find any info on their logs....anyone have any info?
thanks tony
thanks tony
Re: sweetwater log specs?
I know they have a life time warranty to original owner!
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
Pontoon guage, log material, chambered, drain plug etc?HandymanHerb wrote:What kind of info are you looking for ???
Just bought a new 2086 with 27"logs. I don'know the gauge, however they are chambered with no drain plug. Hope this helps.
2015 90 HP Yamaha
2017 4WD GMC Canyon
2015 90 HP Yamaha
2017 4WD GMC Canyon
Really no drain plugs? Have you looked on the inboard sides?ralph wrote:Just bought a new 2086 with 27"logs. I don'know the gauge, however they are chambered with no drain plug. Hope this helps.
I'll double check mine tonight, but I could not find any drain plugs on my Sweetwater tritoon.
[b][color=#0000BF]2014 Sweetwater 2286 TT 150 Yamaha[/color][/b]
[i]It really ties the room together...[/i]
Most likely they are vent plugs on the top of the toons. You won't be able to see them if your toon us under skinned because you have full length risers on the outside and under skinning on the inside.
Yes, I do see vent plugs on the top of the toons, but no drain plugs on the bottom of the toons, like I've seen on some other manufacturers.ToonGuy wrote:Most likely they are vent plugs on the top of the toons. You won't be able to see them if your toon us under skinned because you have full length risers on the outside and under skinning on the inside.
That's not unusual. There are a lot of manufactures that didn't put drain plugs in. Personally, I never understood the logic behind that but to each their own.
That's exactly why I asked! As a ship engineer its hard for me to accept that so much is done without logic.....ToonGuy wrote:... Personally, I never understood the logic behind that but to each their own.
teecro wrote:That's exactly why I asked! As a ship engineer its hard for me to accept that so much is done without logic.....ToonGuy wrote:... Personally, I never understood the logic behind that but to each their own.
I agree, was trying to help out the OP. I like that mine does NOT have drain plugs.
Can't say that I agree with not having drain plugs.... Even ships, tugs and barges have drain plugs; just about every tank space has a flush fitted pipe plug that can be removed from under the hull just in case the need for a drain be needed.....Dude wrote:teecro wrote:That's exactly why I asked! As a ship engineer its hard for me to accept that so much is done without logic.....ToonGuy wrote:... Personally, I never understood the logic behind that but to each their own.
Sweetwater 27” diameter tubes are .090.motocross wrote:Pontoon guage, log material, chambered, drain plug etc?HandymanHerb wrote:What kind of info are you looking for ???
240 DF LF150 Yamaha
Lifting Strakes Cap. 15 Per.
Long Shaft 31.9 mph.
240 DF LF150 Yamaha
