PS I am working on a photobucket album with all the photos
My 86 Playcraft Rebuild
Will here are the pictures for our rebuild 1986 play craft 24 foot we completed the rebuild in 2011. In 2012 we replaced the motor we went from a 50 hp Evinrude to a 88 hp Evinrude at the same time I had to replace the hardtop due to losing it on the highway. For those guys that want to haul their hardtop's down the highway my recommendation would be to use a strap to hold it down I pulled mine for two years with the hardtop down with no problems. I used a pin to hold the uprights to the railing and it worked great, when I went to get a new motor I towed it 300 miles down the road and one of the pivot bolts broke it allowed the top to act like a sail and we went down the road for 30 miles before it ever touched the ground it was too high up in the air for me to see the top in the mirror I can only see the uprights in the mirror the uprights stayed in place. When I got to my destination I got with a weld shop to see what they would charge to fix it they wanted $1500 I said for that I can put two Bimini tops on for that.
- 86Playcraft005.jpg (98.42 KiB) Viewed 13231 times
- 86Playcraft035.jpg (96.05 KiB) Viewed 13241 times
- 86Playcraft011.jpg (77.65 KiB) Viewed 13222 times
- 86Playcraft009.jpg (104.7 KiB) Viewed 13225 times
Re: My 86 Playcraft Rebuild
Here is a link to the rest of the photos.
http://s1327.beta.photobucket.com/user/ ... 0Playcraft
- Texoma Toon
Wow! excellent job rebuilding!
We really have a lot of talent here.
2007 G3 LX 22 Fish & Cruise
90 Hp Yammy
Dual Axle Trailer
90 Hp Yammy
Dual Axle Trailer
GREAT JOB!
Sheridan, Indiana
Sheridan, Indiana
- evinrude2stroke
- Capt Sully
Great job, you did good.
And your the first to list on this new blog
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
FVC USCG Auxiliary
Vietnam 66 / 67
Damn Kenneth that is awesome! I can't believe I can't hear your tunes from my cove!
I'll let you know I go down next time and maybe check it out in person.
prostreetnova65
That's awesome!
Nice looking build, I've got the same bimini top on my boat except red, how do you like yours?
2006 dodge ram quad cab
Crosby Texas
Crosby Texas
Thanks guys for all the comments there greatly appreciated had a lot of fun rebuilding the boat would do it again. Mrtoler in answer to your question yes I like my double Bimini I do miss my hardtop though, because we are fair skinned we burn easily so we use our tops all the time. They do act like big sails though in the wind but that's okay I can live with that.
WOW i am new here and what do i find the first day , this awesome rebuild.
sir i am hoping that you and i can talk either thru here posting back and forth, pm, or the phone . i have the exact same boat and have many questions i need to have answers to before starting my own project.
i will ask one now if i may . did you have any issues with your toons leaking and the foam being soaked , which required fixing ? ( foam replacement or drying ) this will be the first thing i need to address
I did not have any problems with my Toons until I had some work done to them. I had a bracket put on for my live well pump and I believe it must have a hole there. If I remember correctly the foam inside is closed cell, so it should not soak up water. If you will PM me your phone number I will call you.
I have the same curiosity about the foam. When I first got my toon there was about a gallon of water in the port side pontoon. I have found and fixed the leaks, but have wondered about the state of the foam inside.rlcrews wrote: i will ask one now if i may . did you have any issues with your toons leaking and the foam being soaked , which required fixing ? ( foam replacement or drying ) this will be the first thing i need to address
1989 Lowe 189
Evinrude 40
Evinrude 40
- The_Hellbilly
Most of the foam used is "closed cell" foam meaning that it doesn't absorb water. When I had a leak, it didn't bother me to run all day and I didn't have to worry about about the log filling completely with water.rlcrews wrote: i will ask one now if i may . did you have any issues with your toons leaking and the foam being soaked , which required fixing ? ( foam replacement or drying ) this will be the first thing i need to address
2005 Voyager 22ft Tritoon
2004 Honda 135hp
2004 Honda 135hp
