New parts question
Mrtoler
New parts question
#1 Post by Mrtoler » Mon Feb 25, 2013 9:05 pm
I've got some spare change burning a whole in my pocket and I'm going to go ahead and order some of the small things I need on my pontoon that I never did finish.. Like finish out the sink area with holding tank and pump and the counter top. I also never got my gauges, I'm going to get the teleflex lido gauges I'm thinking of a tach, fuel, trim, water pressure and volt gauge. My problem is on the trim gauge they say it works with most brands but I don't see Johnson listed! So will it work with my 96 Johnson 112? And what's involved with the water pressure gauge installation?
Thanks Ryan
2006 dodge ram quad cab
Crosby Texas
cleatus
Re: New parts question
#2 Post by cleatus » Tue Feb 26, 2013 5:14 am
I hardly ever look at my trim gauge, but the other gauges you mentioned are monitored often.
I don't have a water pressure gauge, no help here, you'll have a Johnson guru post info on that for you. I just watch the pisser like it was a gauge.
Good luck with the install, you did a fine job restoring your toon.
here, pull my finger
2011 Godfrey Sweetwater
Yamaha F70
#3 Post by curtiscapk » Tue Feb 26, 2013 7:28 am
Ryan,
not sure how much trim would be used... :rofl :rofl
I watch my water pressure gauge ALL the time. Power for the light and a water line to motor is all you need.
Google psi port for your motor.
My fuel wasn't working..I think it was the sending unit.
redbeard
#4 Post by redbeard » Wed Feb 27, 2013 10:42 am
Yes the trim gauge should work I have a 96 Evenrude and the gauge works for me.
Mrtoler
#5 Post by Mrtoler » Wed Feb 27, 2013 6:28 pm
Thanks, I hear alot of ppl say that the trim gauge is useless but since I can't see my engine from the helm I think it would come in handy since I'm often trimming my motor up at stops and I always have to walk to the back to make sure the motor is down before we take back off..
Crosby Texas
redbeard
#6 Post by redbeard » Thu Feb 28, 2013 9:22 am
Same for me so I use my gauge all the time.
