Best location to mount transducer
- bradcox100
I have searched this forum, but I don't see a best location to mount a transducer for my new Lowrance Elite 4 DSI fishfinder.
I see that most people say to mount the transducer on the bracket that goes around the aerator pump on the left toon at the rear. But I saw where one person has mounted the transducer on the transom.
I haven't drilled any holes yet for the transducer. So what does everybody suggest?
Brad
Brad
Brad & Ali
2013 20' Sun Tracker Fishin' Barge
Mercury 60hp 4-Stroke
2007 Ford F150 Lariat SuperCrew 4X4
Re: Best location to mount transducer
Right bracket. There's no pump there.
1+BobG wrote:Right bracket. There's no pump there.
Since it is a Tracker it probably has a ladder....and no bracket at all.
- SAM_0994.JPG (289.08 KiB) Viewed 8741 times
Be sure and mount the bracket as close to bottom as possible. Toons make lots of bubbles and disturbed water and transducer needs clean water to work right. Don't tighten so much it won't kick up when it hits something.
- evinrude2stroke
On the bracket. It also has to be level. Your kit should have shims in case you need them. Be sure to use stainless steel hardware.
Dave
evinrude2stroke wrote:On the bracket. It also has to be level. Your kit should have shims in case you need them. Be sure to use stainless steel hardware.
Level on a side to side you mean? It doesn't on vertical because transducer is adjustable
- bradcox100
I think curtiscapk is correct, I can't find a bracket on the right side of my Tracker. So I will mount it on the aerator bracket on the left side. I just wanted to be sure before I start drilling into our new boat, ha.
- Back of Boat.jpg (152.68 KiB) Viewed 8598 times
Brad & Ali
The first hole is the hardest. After that, it gets easier.bradcox100 wrote:I just wanted to be sure before I start drilling into our new boat, ha.
That's like the first time I took a sawzall to the fender openings on my 1995 Suzuki Sidekick (with 33" tires).
I have a tracker also-and it has brackets on both toons.
I have a transducer on both.
steveiam wrote:I have a tracker also-and it has brackets on both toons.
with a rear ladder?
My '03 Suntracker doesn't have a ladder in the rear...so mine is mounted to the right bracket....
Jim & Jill
East Peoria, Il.
Illinois River Tooners
90hp Tracker Mercury
"the Jillie Marie"
East Peoria, Il.
"the Jillie Marie"
Yes Sir--curtiscapk wrote:steveiam wrote:I have a tracker also-and it has brackets on both toons.
with a rear ladder?
It is a transducer for down/side imaging and when we are using the ladder we just flip it up.
Here is a closer shot-
