andrew_
#1
Post
by andrew_ » Tue Jun 18, 2013 8:51 pm
I have an old '88 Harris Kayot and everything from the fence supports to the door stops are welded on. Ugly in a lot of ways, but solid as a rock. Unfortunately the doors rattle in the door stops something awful. To the point of extreme annoyance at full throttle.
I'll post an actual picture of them, but for the time being this is pretty much what it looks like:
There is about a 1/4" of play in the door stop bracket and no other hardware (other than the pin hinge) that is present on the door or the supporting rail/fence.
Any creative suggestions on how to create a snug fit and kill the rattling?
Post
by HandymanHerb » Tue Jun 18, 2013 9:10 pm
Well it is suppose to drop into that bracket, did some one replace with a non drop hinge ?
andrew_
#3
Post
by andrew_ » Tue Jun 18, 2013 9:11 pm
It's the old school pin style hinge, but it is a liftable hinge, and it does drop into that. There's just a lot of play in the bracket and it causes lots of rattling.
Post
by HandymanHerb » Tue Jun 18, 2013 9:54 pm
OK then you can get some foam rubber for it to drop into to stop the rattle
BillieS
#5
Post
by BillieS » Wed Jun 19, 2013 4:29 am
Mine does the same thing when I am trolling. I am going to try and put the fuzzy side of velco on both side to dampen the vibration. Too thick and the door will not close.
2008 SunTracker Fishing Barge signature series 21/60HP Bigfoot 4 Stroke EFI, 85# Thrust Minn Kota Terrova Trolling motor W/Remote control and foot pedal
OK Toon
#6
Post
by OK Toon » Wed Jun 19, 2013 6:01 am
You should be able to take any fabric or material that is thin and glue it to the insides of the bracket where the door slides into it. This should dampen the rattle noise.
My doors have plastic brackets so the metal door frame doesn't rattle while it is closed - they also serve as a riser to help keep the fence off the deck.
- boat_door_stop.jpg (130.56 KiB) Viewed 3608 times
andrew_
#7
Post
by andrew_ » Wed Jun 19, 2013 6:04 am
The problem with anything sticky/glued etc that I've tried this morning is that when the door is put back into the stop, if it's not done with great care, the corner of the door peels off whatever material the stop was lined with.
Unfortunately switching to plastic stops isn't an option as the old ones are welded on. Got a couple of opinions that removing it would damage the fencing. Not something I'm willing to do.
GXPWeasel
#8
Post
by GXPWeasel » Wed Jun 19, 2013 6:11 am
Put the foam rubber piece on the bottom of the bracket, not on the sides. This won't allow the door to come all the way down to the ground, (about 1/4 from the floor instead) but it would prevent rattling. No worries about peeling anything off the sides of the bracket either then.
"Nauti Weasel"
2005 Beachcomber Islander 26
BoatCop
#9
Post
by BoatCop » Wed Jun 19, 2013 6:35 am
You could get a gate latch to hold the door tight. Mine came with them.
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
Capt Sully
#10
Post
by Capt Sully » Wed Jun 19, 2013 6:57 am
if you have some old water hose laying around, cut a 1" section and just snap it on the bottom of the gate
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
Post
by lakerunner » Wed Jun 19, 2013 7:41 am
We painted the bottom with liquid electrical tape.
Ron Burgundy
#12
Post
by Ron Burgundy » Thu Jun 20, 2013 6:57 pm
I stick my flip flop in the crack. It only rattles at idle.
