Merc 90 over rev
tracker2
Merc 90 over rev
#1 Post by tracker2 » Sat Jul 13, 2013 6:49 pm
Checked out 19 pages on a search with no luck.
Here's the problem.. 1999 Suntracker, 21' Party Barge. 1999 90 H.P. 2 stroke Merc. Running a 13-3/4 X 17 Vortec prop. WOT is 6100 RPM. Engine is supposed to be in the 5000 to 5500 range. My question is .. Will a 19 pitch bring the R's down in range or will I need to go to a 21? This is light load with 3 adults and small child... Don't have a speedo or GPS so no speed is known. Any suggestions?
cwag911
Re: Merc 90 over rev
#2 Post by cwag911 » Sat Jul 13, 2013 7:15 pm
Are you sure your tach is correct? A 17p on a 90 HP motor sounds like too much prop and shouldn't give you that rpm unless the prop is slipping or cavatating.
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
#3 Post by Bamaman » Sat Jul 13, 2013 9:47 pm
Carl might be right about the tachometer. You might want to have it checked for accuracy.
The current Mercury 90 hp 2 stroke is running a 2.33:1 gear ratio which would mean it may use a propeller with high pitch.
FYI: A Mercury 115 hp 2 stroke has a 2.07:1 gear ratio and they'd run a lower pitch prop since the prop's turning over faster. I
But if your tachometer is correct, you probably need more pitch to bring the rpm's down to 5500 ish.
slingshot
#4 Post by slingshot » Sun Jul 14, 2013 6:48 am
Just remember, for every inch of pitch you adjust, you will effect your RPM by about 200.
2007, 2570 Crest LE II
Yamaha F150
tracker2
#5 Post by tracker2 » Sun Jul 14, 2013 4:33 pm
OK, Houston, we have a problem. After borrowing a gps, I find wot speed is 14.3 mph. tach is reading 6100. Upon idling down and kicking out of gear, tach is reading 2000. First problem first, I got to get a new tach. Then back to the prop.....Thanks all...
jrolin1
#6 Post by jrolin1 » Mon Jul 15, 2013 3:46 am
Most outboard tachs have a switch on the back for you to set the number of cylinders the motor has. You may want to check that before replacing it. Even if it is set right I would change it and then change it back to see if that helps.
tracker2
#7 Post by tracker2 » Mon Jul 15, 2013 8:43 am
Never gave the switch a thought. Good idea. Also have a strong suspicion that the hub is spun on the prop. Even tho it is new.
Has anyone had an trouble with the hub on the Vortec props.
mike
Site Owner
#8 Post by mike » Mon Jul 15, 2013 10:50 am
yep, check the switch on the back of the tach. Mine was set wrong when I got my toon.
