Hard top braces
Vaughn
Hard top braces
#1 Post by Vaughn » Wed Jun 03, 2009 6:23 am
Another questions.
We think we found why our hard top is rocking so much. There seems to be a brace missing on the back, anyway there are some empty holes where it looks like a brace should go.
Anyone have one and know for sure?
Fritz
Re: Hard top braces
#2 Post by Fritz » Wed Jun 03, 2009 6:37 am
Do you have any pics of it? I have 2 friends with hard tops.
Fritz
Sweetwater 2386 RE Sport
Wichita,Ks
sHan tn
Re: Hard top braces
#3 Post by sHan tn » Wed Jun 03, 2009 8:09 am
our hard top bolts to the railings and rock a LOT so i used "very small" cable in a big V from the top outer corners to the middle of the floor behind the rear gate, then i used 2 small turn buckles to tighten the cables and no more shake or rock. the cables are hard to see.... and the way they are set up when i fold the top down they just lay faward and i dont have to do anything with them :)
:drive
1982 Sylvan 24' Toon
50hp Evenruder
my fishin/camping boat
An unarmed man is a subject.
911: Government sponsored Dial-a-Prayer.
When seconds count....Police are minutes away
mikeherb
Re: Hard top braces
#4 Post by mikeherb » Wed Jun 03, 2009 8:54 am
We had a hardtop on an old '86 toon that rocked like crazy. I used some flat metal and clamps to gusset the top and removed a lot of the movement.
sHan tn
Re: Hard top braces
#5 Post by sHan tn » Wed Jun 03, 2009 11:20 am
here is the cables i used for mine. (i lower the top on mine to trailor it) so i needed somthing simple :)
here you can barely see them
here it is close up
and it is solid as a rock now, i can tighten the turn buckles if the cable streches any
:drive
50hp Evenruder
Vaughn
Re: Hard top braces
#6 Post by Vaughn » Wed Jun 03, 2009 7:17 pm
Thanks!!!
I would post pictures, but haven't seen where to do it!
sHan tn
Re: Hard top braces
#7 Post by sHan tn » Wed Jun 03, 2009 7:43 pm
Vaughn wrote:Thanks!!!
Above the post box it has the little boxes there and the one that says "IMG" is the on you want. when you click on it paste the url of your picture (in the middle of the 2 Img's)
50hp Evenruder
Vaughn
Re: Hard top braces
#8 Post by Vaughn » Thu Jun 04, 2009 7:13 pm
(edit picture smaller)
pontoon ride 5-30-09 smith 044 (Small).jpg (53.01 KiB) Viewed 8775 times
Vaughn
Re: Hard top braces
#9 Post by Vaughn » Thu Jun 04, 2009 7:16 pm
oops, sorry I sent it way too big. You can take it off or resize it, not sure of how to do that either!
Re: Hard top braces
#10 Post by HandymanHerb » Thu Jun 04, 2009 9:46 pm
You can hit edit to replace it with a resized picture
Fritz
Re: Hard top braces
#11 Post by Fritz » Fri Jun 05, 2009 6:48 am
Sorry I can not help. The ones that my friends have are solid hard tops and do not fold down.
Fritz
Wichita,Ks
Vaughn
Re: Hard top braces
#12 Post by Vaughn » Wed Jun 10, 2009 5:41 am
My husband looked closer and found all the bolts just needed to be tightened down more and replaced under the side! He also looked at the guy's that posted on here and rigged up a similar
contraption. It does a whole lot better.
The hard top seems to be alot cooler than the soft fold down we had.. We went out this week and it was nice even tho it was nearly 90 degrees.
Gary
Re: Hard top braces
#13 Post by Gary » Tue Jun 16, 2009 6:23 pm
I have a similar top on my boat with similar problem. However I am trying to find replacement vinyl for the rubrail that surrounds the top. Any ideas? anyone?
2009 F150 Crewcab
Guntersville Lake Alabama
Re: Hard top braces
#14 Post by badmoonrising » Wed Jun 17, 2009 7:55 am
Welcome Gary. You might find what you're looking for here:
http://www.rubrails.com/
