Dirty toons = slower speed?
evotuner
#1 Post by evotuner » Thu Sep 12, 2013 7:04 pm
Purchased new triton this year and keep it in a slip. 24' w/ Merc 150, both boat and motor are brand new. Anyway, earlier this year, I could run 36-39mph w/ my family on board. Last weekend, took boat out, would only do 29mph, same weight on board. I was guessing I had water in one of my toons. Pulled out the boat today, no water, but my toons were all covered in moss. Is it possible this is what is slowing down my boat? Boat runs fine besides that.
Thanks!
Re: Dirty toons = slower speed?
#2 Post by Bryden24shp » Thu Sep 12, 2013 7:37 pm
Oh ya! You'll feel the difference again when you get them clean!
jafo9
#3 Post by jafo9 » Fri Sep 13, 2013 12:18 am
yup. clean dem toons.
2002 MasterCraft X30
2007 Yamaha FX HO Cruiser
2005 Kawasaki SXR800
2004 Yamaha SuperJet
1989 Kawasaki 650sx
Lewis Smith Lake, Alabama
Cycleman07
#4 Post by Cycleman07 » Fri Sep 13, 2013 6:20 am
once you get them cleaned please Sharkhide your toons. Protect your investment. Our Toons are often like tires for some people. Its the only part that keeps your boat from sinking and yet they are often neglected. Clean them thoroughly and then sharkhide them. It last about 3 years before needing to be reapplied. All that is required after a day on the lake is a fresh water wet washcloth and wipe them down. My boat is brand new and before it ever saw the water I applied sharkhide. If you are familiar with Keystone Lake (West of Tulsa Ok) you will know it has a tendency to get a little muddy. I still have no waterline showing at all and my boats performance is increasing due to the motor being broken in.
Here is a link to their metal protection product.
http://www.sharkhide.com/mpinfo.html
And no, I dont represent Sharkhide in any way
#5 Post by Bamaman » Fri Sep 13, 2013 6:53 am
If you keep your boat in the water most of the time, it's best to take ScotchBrite pads and clean the hull every time you use it.
That'll minimize major grunt work it'll take to clean the toons later.
REPETE
#6 Post by REPETE » Fri Sep 13, 2013 9:16 am
Faster maybe...but 10-15 MPH? I don't think so. It'll help but not that much.
smoker62
#7 Post by smoker62 » Fri Sep 13, 2013 10:41 am
I agree with repete. I leave mine in the river from april to october . Gets pretty scummy but I never lost more than a couple mph.
BobL
#8 Post by BobL » Fri Sep 13, 2013 12:47 pm
I lose close to 6-8mph with dirty toons (keep in the water in Louisiana). At least 3 times a summer, I get under the boat and scrape with one of those nylon plate scrubbers and the Scotch Brite Pads.
http://www.amazon.com/Fox-Run-Nylon-Pot ... B0000CFMA4
Takes me about 30-45 minutes but a good excuse to get in the water and take a sip of beer every 10 minutes.
rbiederwolf
#9 Post by rbiederwolf » Fri Sep 13, 2013 2:14 pm
Dirty toons create huge drag. Scrub them every so often while at a sandbar and you should be fine.
2008 Yamaha 150hp
katieclooney
#10 Post by katieclooney » Fri Sep 13, 2013 5:21 pm
But which Sharkhide product?
foster brooks
#11 Post by foster brooks » Sun Sep 15, 2013 2:43 pm
yep evotuner you are correct, moss=drag
Rock River illinois pool 5
2013 sylvan mirage cruise LE
fridge full of beer
rsmith
#12 Post by rsmith » Sun Sep 15, 2013 6:18 pm
yup, I easily lose a good 5 mp or more when the logs get dirty. I used a wide plastic putty knife to scrape my logs a few times a year and if I'm ambitious I'll use a scotch brite pad after the putty knife to get them a little cleaner.
200hp Mercury Verado
#13 Post by HandymanHerb » Sun Sep 15, 2013 6:29 pm
katieclooney wrote:But which Sharkhide product?
Use the metal protector after it's clean
moregooder
#14 Post by moregooder » Tue Sep 17, 2013 2:57 pm
I also have a bad case of moss drag. we applied sharkhide last winter hopping it would slow the growth down or at least make it easier to get it off. No such luck, at least the logs are still shinny after I blast and scrap the moss off.
The boat stays in 7 months and the hole point of getting the slip in the first place was not to have to mess with hollen the bot out. so this week end I am pulling her out cutting the sharkhide off the submerged portion off the logs (sharkhide has kept the logs nice and shinny) and applying a good ant fowling paint ( without copper) this is the only part of my winter overhaul that didn't work out the way that i planed
willy13
#15 Post by willy13 » Wed Sep 18, 2013 6:32 am
Please post back after you clean the toons and let us know if you gained your speed back. Thanks!
