Thinking abt a new toon
Jake202
#1 Post by Jake202 » Sat Feb 22, 2014 9:13 pm
Last year all summer long we had talked about doing some upgrades to our toon and I researched here and online about adding a third toon and possibly a bigger motor. Hadn't thought much more about it seeing as I didn't really want to spend the money on upgrades nor do I have the place to do them. Some people I work with had told me about going down to a boat dealer here and they upgraded to a tri toon and got a really good deal. So I started thinking about it again and started looking at trading in mine and upgrading to a tri toon. I have found one I really like and considering it. Its got a 115 on it, which im sure will be plenty of power to do what we need it to do but I think I'm gonna spend the extra and have a 150 put on it. How do the U shaped pontoons match up to the regular round toons?
image (2).jpeg (272 KiB) Viewed 4985 times
image (1).jpeg (248 KiB) Viewed 4983 times
Re: Thinking abt a new toon
#2 Post by Bamaman » Sat Feb 22, 2014 9:53 pm
My old pontoon was a Starcraft with the U shaped toons. It is the best riding, most buoyant twin toon boat I've ever ridden in. Playcraft is about the only company still making U toons, however.
It all comes down to dollars and cents. Have you shopped other brands? I went Bennington on my new pontoon, and am very well satisfied with it. The most popular brands of pontoons all have 3-4 different model boats in every price range.
And if you're going tritoons with strakes, take advantage of that hull and go with the 150 hp motor. You won't be sorry.
captainjack
#3 Post by captainjack » Sun Feb 23, 2014 6:08 am
I like mine rides good
2008 Playcraft Extreme 2600
2008 300 Mercury Verado
2008 Bear Trailer
Iowa
sunnyside
#4 Post by sunnyside » Sun Feb 23, 2014 7:33 am
Have to agree with above. Go with at least 150 HP since you have higher performance tri-toon pkg. You won't regret it and may even wish you went bigger. That's one reason I'm on second toon in a year.
2014 Bennington 2375 RL, ESP Pkg, many options, Evinrude ETEC 225HO
Woody
#5 Post by Woody » Sun Feb 23, 2014 8:51 am
U shaped toons are supposedly more buoyant than similar sized round toons, as there is no water weight "pushing down" on the toons once/if the center of the toon is @ the water line. My JC Tri Toon (the original "tri toon") has 3 U shaped logs, and I couldn't be happier with them.
As stated above, get the biggest motor you can afford...
2019 Veranda 22 RFL 250SHO
cwag911
#6 Post by cwag911 » Sun Feb 23, 2014 9:34 am
Yup, what they said. Go big or go home, as long as the wallet can handle it. :biggrin2
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
bassn386
#7 Post by bassn386 » Sun Feb 23, 2014 12:30 pm
With those lifting strakes I don't think it will make much difference as to the shape of the logs. Definitely go for the bigger motor.
One thing I did find out with the lifting strakes on my toon is that you need to be a bit more pro-active about throttle settings. I was used to having my v-hull settle into the water and basically come to a stop with the throttles at neutral. At least with my Benni, I find the boat is still moving forward after I come to neutral. It was a bit disconcerting at first, but I learned to slow down well ahead of coming into a slip or a dock so I didn't have to slam it into reverse.
Something else to watch out for if the throttle is digital. There is no "shift button" from forward to neutral to reverse. It's a very subtle feeling in the throttle handle, so if your new toon comes with that be aware of where neutral is. I scraped up my logs very early in my ownership and I'm now hyper-aware of the position of the throttle.
Good luck and happy boating!
F225 Yamaha
Rascal
#8 Post by Rascal » Sun Feb 23, 2014 5:26 pm
Are the logs filled with foam....?
Rascal
Fishing Year Round SW Florida
Premier 22' 2012 Cast A Way
115 hp Honda, 15.5 x 13 prop
Sea Star Power Steering
Day Enclosure
Loan Star Anchor Winch
Fixed Mount ipad Air for
Cycleman07
#9 Post by Cycleman07 » Mon Feb 24, 2014 7:17 am
My first Toon was a G3 and I was very happy the U shaped logs just not the layout (it was a fishing model, and I rarely used it for that). G3 at least in 2010 still used foam in their logs. They make a quality product.
Johnboy
#10 Post by Johnboy » Mon Feb 24, 2014 12:56 pm
We purchased a G-3, 326 Elite SS last year and could not be happier. The U shaped logs seem to handle all types of water conditions with no problem. I have had the boat on 3 of the Great Lakes: Superior, Michigan and Huron. The boat seems to ride high in the water, we dock it on the inland lake we live on and it allows us to traverse rather shallow water to get it to the hoist. The logs are filled with closed cell foam. The nose cones on the G-3 are now .200 gauge with the rest of the logs .100 guage. The boat appears to be put together solid, at least on the model I got the cross members are 16 on center like most manufactures do now.
So far I am happy with our decision to go with the G-3. I was a little leary at first going with the U-shape foam filled logs.
Good luck in your decision.
2013 Elite 326 SunCatcher-G-3, 250 Yamaha SHO 4 stroke
Rascal
#11 Post by Rascal » Mon Feb 24, 2014 6:37 pm
I've been told to avoid pontoons that are foam filled like the pox. They (who is "they"), That you can't weld on them because of the foam inside, and if you get a water leak your up shit creek without a welder that will touch the job.
Just..... what "they" say.
Your call... roll the dice?
Rascal
Day Enclosure
playcat
#12 Post by playcat » Mon Feb 24, 2014 6:57 pm
My Playcraft barge is a '93 and still going strong,even if the old Volvo won't...held up to its 235 ponies really well so far!
playcat
JC 266 TriToon
Kerr Reservoir, VA
Drago
#13 Post by Drago » Mon Mar 03, 2014 11:44 am
The JC Tritoon had a nice very water saavy design. Strange thing is I cannot find a dealer anymore within 250 miles of me.
http://www.jcpontoon.com/unique-hull-design.html
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
