Hand controlled Bow mount controlled Trolling Motor? Mounted
Hawk_308
#1 Post by Hawk_308 » Mon Apr 28, 2014 8:47 pm
Im looking at this Trolling motor http://www.amazon.com/gp/product/B003CK ... d_i=507846
I dont want one that stores on deck because one I would have to modify the door and I dont want it in the way of my disabled son since if we go to town on the boat we will have his wheel chair on board. And I cant find any others that store vertical . Minn Kota is out for personal reasons Had 2 of them fail during tournaments :censored Im just worried that to get the varimax in the water Ill have to have the head almost on the floor which will be a PITA to operate . Im planing on mounting it on the port side just inside of the of where the foot rest rail is . If it is to short I wondered how hard it would be to cut it and extended it between the mount and head .
1988 24' Party Barge pushed by a 75hp cmc trim 17p 4 blade prop
wijames
Re: Hand controlled Bow mount controlled Trolling Motor ?
#2 Post by wijames » Wed Apr 30, 2014 7:45 am
Hawk_308 wrote:Im looking at this Trolling motor http://www.amazon.com/gp/product/B003CK ... d_i=507846
I have one on my toon and love it. I mounted it sideways on the right side but had to remove part of my side rail in the front. It works great. Here is a picture of how it looks for you.
(old) 2000 Sylvan 20' Tritoon
Hawk_308
#3 Post by Hawk_308 » Wed Apr 30, 2014 3:23 pm
Thanks , The one Im going to order is going to have the simple pontoon mount so it is going to just slide up and down . Is yours a 50" , does it sit a comfortable height ? How does it pull you along ?
saltydawg2
#4 Post by saltydawg2 » Wed Apr 30, 2014 5:24 pm
I have one mounted at the front, just to the right of the bump bars, on my 20' Sweetwater. I bolted a heavy, aluminum angle to the front, and then bolted 5/4 treated decking to that; just large enough to be able to bolt the transom on. I turned the head around 180 degrees so blades and handles would face the back. Pontoons are only 19", so only needed 42" shaft on troller. Tried it out the other day, and it worked great. 55# thrust moved it more quickly than needed at higher speed, but it was mostly calm lake waters. I had a little space between the console and rail, so I store it there, and lock it, out of the way. Want picture, let me know.
wijames
#5 Post by wijames » Thu May 01, 2014 6:47 am
Hawk_308 wrote:Thanks , The one Im going to order is going to have the simple pontoon mount so it is going to just slide up and down . Is yours a 50" , does it sit a comfortable height ? How does it pull you along ?
Yes mine is the 50" and it does quite nice even in a strong wind. The height is great and easy to control without being in the way when fishing
saltydawg2
#6 Post by saltydawg2 » Thu May 01, 2014 3:34 pm
Here are the photos I mentioned.
Hawk_308
#7 Post by Hawk_308 » Thu May 01, 2014 7:45 pm
Thanks to both of yall , I pulled the trigger tonight and it was 58 bucks cheaper. I was going to get the reman one for 361 but for 38 bucks more I got it from amazon so Ill have it monday , I was hoping they had it at the local amazon wharehouse if they did it would be here tommorow at lunch .Love me some Amazon prime .
Hawk_308
#8 Post by Hawk_308 » Fri May 02, 2014 6:46 pm
Well picked up 2 group 27s today , now only if brown santa will get into gear . I guess Ill build the boxes for them . Im thinking about tring something like this for charging http://www.dualpro.com/media/pdf/charge ... %20run.pdf
Hawk_308
#9 Post by Hawk_308 » Tue May 06, 2014 5:05 pm
The MotorGuide VariMax 75 lbs thrust 24 volt 50" pontoon mount is Mounted , still havnt done the battery box or wiring yet but here is was I done this evening .
From the seat
UP Periscope
I guess this will hold it if the factory 2 locks fail , it has the squeeze slider and the twist lock
