Water in Fuel...
ToonGuy
Water in Fuel...
#1 Post by ToonGuy » Wed Jul 30, 2014 5:10 am
What's the second best way to deal with water in the fuel? I realize the best way is to drain / clean / replace however while I search for a suitable container for 100+ gallons of fuel I thought I'd ask if any one has another idea...
teecro
Re: Water in Fuel...
#2 Post by teecro » Wed Jul 30, 2014 5:37 am
One tank or several?
(1) Water is heavier than gas thus you can thieve off the water by siphoning from the lowest spot in the tank.
(2) Let settle and repeat step one again.
(3) Add a heavy dose of Marine Stabil or Sea Foam fuel additive as it can help displace some of the remaining water.
(4) Add a Racor branded water removing fuel filter system....
ToonGuy
#3 Post by ToonGuy » Wed Jul 30, 2014 5:59 am
Not sure...haven't ran a full tank through yet. Have the water separator (s) already. Evidentially I'm terrible at siphoning because I tried that once :lol3
I'll keep at it. I'll drain the tanks when I can find something suitable to hold 100+ gallons of fuel!!!
#4 Post by lakerunner » Wed Jul 30, 2014 6:40 am
Just tilt boat with jack, get hose with a primer bulb and pump till only gas comes out.
ToonGuy
#5 Post by ToonGuy » Wed Jul 30, 2014 6:43 am
Easier said then done...twin tanks mounted inside the outer tubes makes it hard to tell if you get the hose straight down in the tank and not curling up. I'll take another stab at it, and be a bit more careful this time.
teecro
#6 Post by teecro » Wed Jul 30, 2014 6:47 am
ToonGuy wrote:Easier said then done...twin tanks mounted inside the outer tubes makes it hard to tell if you get the hose straight down in the tank and not curling up. I'll take another stab at it, and be a bit more careful this time.
Piece of stiff wire and a small hose clamp and that hose will be easy to direct.
ToonGuy
#7 Post by ToonGuy » Wed Jul 30, 2014 7:25 am
Thanks for the tip!
fergusmj
#8 Post by fergusmj » Wed Jul 30, 2014 9:39 am
I can hold 26 gallons in my truck. I'll come up and let you put some in there....keep the water though :biggrin2
Ferg's Tritoon Build
#9 Post by lakerunner » Wed Jul 30, 2014 9:43 am
ToonGuy
#10 Post by ToonGuy » Wed Jul 30, 2014 10:14 am
Hey Loyd what I need is some of those filers with the site window / drains...I already have the dual auxiliary filter units. I'll have to look those up...thanks!
ToonGuy
#11 Post by ToonGuy » Wed Jul 30, 2014 10:15 am
fergusmj wrote:I can hold 26 gallons in my truck. I'll come up and let you put some in there....keep the water though :biggrin2
I know...I'll sell you the boat and you can do what ever you want with the fuel :rofl
fergusmj
#12 Post by fergusmj » Thu Jul 31, 2014 6:37 pm
hmmmmm......i'm scared of one motor right now, lol. don't need 2 :nono
NonHyphenAmerican
#13 Post by NonHyphenAmerican » Fri Aug 01, 2014 7:41 am
PVC Pipe hooked to tubing?
Also, check to see if the tank has a drain valve.
I had a Honda Outboard for my little fishing boat and the tank had a drain on the bottom.
kiowacampers
#14 Post by kiowacampers » Fri Aug 01, 2014 8:41 am
We used a small pipe and wire since we didn't have a clamp, and used a small pump to get it started, then let gravity take over. Worked great.
IMG_1626 (800x600).jpg (260.08 KiB) Viewed 4892 times
IMG_1622 (800x600).jpg (296.74 KiB) Viewed 4892 times
Carol and Jesse (aka The Bickersons)
2006 Suntracker 32ft. Regency Signature Party Cruiser w/150hp Merc Optimax
2003 Ford F350 Diesel 6.0
11 ft. Quicksilver 330 Dinghy w/15hp Evinrude
A massive amount of dogs
In the middle of nowhere, Agate Colorado
babock
#15 Post by babock » Fri Aug 01, 2014 3:43 pm
Please tell me that's a fuel pump.
Mercury 90 4 stroke
