Gasoline
babock
Re: Gasoline
#16 Post by babock » Mon May 11, 2015 2:31 pm
Take into account the extra drive with the boat and buy whatever ends up being cheaper.
The horror stories people have about ethanol are just that....stories. Our entire state has ethanol in our fuel and you don't see boats failing left and right!
http://www.boatus.com/magazine/2011/dec ... thanol.asp
Mercury 90 4 stroke
katieclooney
Re: Gasoline
#17 Post by katieclooney » Mon May 11, 2015 5:57 pm
peedee wrote:Do you get rebates on gas tax for your boat? Here in Delaware we get back $0.23 a gallon on gas used for your boat.
Illinois give credits? hahahahahaha :happy no. we dont get any break for gas.
So now the next question, why kind of fuel treatment do I put in? Last boat was a 2 stroke so I used marine oil.
babock
Re: Gasoline
#18 Post by babock » Mon May 11, 2015 9:39 pm
Any treatment you would normally do is fine. There is no special treatment for fuel containing ethanol that does anything special no mater what they advertise.
Mercury 90 4 stroke
RobZ71LM7
Re: Gasoline
#19 Post by RobZ71LM7 » Tue May 12, 2015 3:15 pm
With modern fuel injected engines and a tight fuel system you shouldn't have an issue. That being said my fuel lines are SAE J30R9 and I use Stabil Marine/Ethanol treatment along with this bad boy:
http://www.amazon.com/gp/product/B000N9 ... UTF8&psc=1
Of course if moisture gets in a bad seal the filter cannot fix that.
FWIW: I had a muscle car sit for 24+ months with the same fuel in it containing 10% ethanol and stabil. It started right up and ran with no issues. I even siphoned the entire tank and put it into my 2011 Corolla without a hiccup. Yes ethanol is sensitive to moisture contamination, but a lot of what is gets blamed for is due to contributing factors.
http://www.veyance.com/ProductsDetail.aspx?id=5144
Spend time at Nolin Lake, KY
hypnoj
Re: Gasoline
#20 Post by hypnoj » Tue May 12, 2015 4:34 pm
So this is an important subject. Getting my new boat this Friday. Does this mean I don't need to worry about Ethanol in these brand new motors? Or do I need to go on a search for ethanol free gas stations around my town?
katieclooney
Re: Gasoline
#21 Post by katieclooney » Tue May 12, 2015 8:08 pm
I picked this up at Menards tonight. Has anyone used this brand? The marina kept preaching Valvtech buy no stores carry it by me that are open after work.
http://www.explosivepowersports.com/luc ... 6oz-10576/
babock
Re: Gasoline
#22 Post by babock » Tue May 12, 2015 10:36 pm
katieclooney wrote:I picked this up at Menards tonight. Has anyone used this brand? The marina kept preaching Valvtech buy no stores carry it by me that are open after work.
It's basically Naptha with a little bit of oil on it.
The fact that it says it treats ethanol means nothing. Basically, there is no additive that does anything for ethanol.
Mercury 90 4 stroke
babock
Re: Gasoline
#23 Post by babock » Tue May 12, 2015 10:37 pm
hypnoj wrote:So this is an important subject. Getting my new boat this Friday. Does this mean I don't need to worry about Ethanol in these brand new motors? Or do I need to go on a search for ethanol free gas stations around my town?
You don't. 10% ethanol has around 3% less BTUs in it that non ethanol so that is the only difference you will notice.
Mercury 90 4 stroke
Re: Gasoline
#24 Post by ROLAND » Wed May 13, 2015 1:55 am
I'm not a chemist by any stretch of the imagination so I can only give you my personal experience.... at the beginning of last season I filled my boat up with ethanol free fuel... I also added a stabilizer called pri-g. Didn't use the boat all that much last season, so when spring rolled around this year, the fuel that was in my boat was about 13 or 14 months old... she fired right up and has been running great this season... I will say yes, there are ethanol treatments you can add to your fuel with ethanol, but if you can put ethanol free fuel in your tank, then you don't have to worry at all about it.. just add a good stabilizer and you'll be good to go.... just my opinion, if you're interested in locating ethanol free fuel, check out the web site www.pure-gas.org. hope this helps.
katieclooney
Re: Gasoline
#25 Post by katieclooney » Wed May 13, 2015 5:40 am
So I shouldn't use this?
katieclooney
Re: Gasoline
#26 Post by katieclooney » Wed May 13, 2015 5:42 am
ROLAND wrote:I'm not a chemist by any stretch of the imagination so I can only give you my personal experience.... at the beginning of last season I filled my boat up with ethanol free fuel... I also added a stabilizer called pri-g. Didn't use the boat all that much last season, so when spring rolled around this year, the fuel that was in my boat was about 13 or 14 months old... she fired right up and has been running great this season... I will say yes, there are ethanol treatments you can add to your fuel with ethanol, but if you can put ethanol free fuel in your tank, then you don't have to worry at all about it.. just add a good stabilizer and you'll be good to go.... just my opinion, if you're interested in locating ethanol free fuel, check out the web site http://www.pure-gas.org. hope this helps.
Thanks for the link! I plan on stopping for the ethanol free gas when im on that side of the lake. However I need gas to get to that side lol. Not to mention if I am never near that spot I want to have the right treatment on hand
babock
Re: Gasoline
#27 Post by babock » Wed May 13, 2015 7:50 am
You don't need to treat it. The only danger of ethanol is if you get too much water in the gas, you get phase separation. There is absolutely no chemical known to man that will prevent this from happening or remove it once it happens.
You treat ethanol fuel the same way you treat non ethanol fuel. It does almost exactly the same thing. Main thing it does is add a little oil to your fuel to help keep it from oxidizing.
Mercury 90 4 stroke
katieclooney
Re: Gasoline
#28 Post by katieclooney » Wed May 13, 2015 8:36 am
babock wrote:You don't need to treat it. The only danger of ethanol is if you get too much water in the gas, you get phase separation. There is absolutely no chemical known to man that will prevent this from happening or remove it once it happens.
And the way you get water in your tank is if you have a broken seal?
BobG
Re: Gasoline
#29 Post by BobG » Wed May 13, 2015 9:39 am
katieclooney wrote:And the way you get water in your tank is if you have a broken seal?
As a Union Steward for Sea Lions Local Union 5573, I cannot condone the harassment, debasement, nor any mechanical manipulation of any Seals.
:rofl :smoke :drink4
crookedlaker
Re: Gasoline
#30 Post by crookedlaker » Wed May 13, 2015 10:24 am
after reading the article above, from Boats US on ethanol fuel, it looks like the most important thing is to
keep your tank full to prevent condensation.
Buy fresh fuel (see my earlier post in this thread)
Use fuel stabilizer for storage
optional to add fuel treatment to prevent oxidization
Mike
2017 Harris Sunliner 200
Tri-toon P+ Package
2017 Mercury 150 4 stroke
