restoration of 1990 Sweetwater
kcdaniels
#1 Post by kcdaniels » Wed Jul 22, 2015 11:11 am
Ok a newbie question....lol... I'm starting my restoration on my 20' Sweetwater and I want to lift it off the trailer...how do I go about that :donno ....
1990 20' Sweetwater
1994 55 Suzuki 2 stroke
GPS 20 mph two people
Central Florida
turbom700
Re: lifting boat off trailer
#2 Post by turbom700 » Wed Jul 22, 2015 2:09 pm
Here is what I did,
I let the tounge of the trailer all the way on the ground then built this
I then took a engine hoist and picked the tounge of the trailer up high enough so that when I let it down I could slide it out.
You then get this.
Once out I used a floor jack and picked each corner up a tiny amount and put 4x4 right under the pontoons in each corner. Then put a ton of cross braces.
Good luck
kcdaniels
#3 Post by kcdaniels » Wed Jul 22, 2015 4:31 pm
Pictures worth a thousand words...lol... thanks for the post...started pulling the rails tonight...looks like the carpet going to come up a lot easy than I thought...
Guess I should rename this post as my restoration...my plan is to paint the toons along with the skin on the rails...made the mistake of going to Bass Pro and saw a $86 k pontoon :scared ...but it was all painted and looked sharp....
Dan
1990 20' Sweetwater
Central Florida
COTTS4x4
#4 Post by COTTS4x4 » Wed Jul 22, 2015 7:30 pm
Here's how we got mine off!
[b][i]
[/i][/b]
kcdaniels
#5 Post by kcdaniels » Wed Jul 22, 2015 7:42 pm
Nice !!!
1990 20' Sweetwater
Central Florida
#6 Post by Bamaman » Wed Jul 22, 2015 8:00 pm
All it takes is some ingenuity. And a big oak tree to tie the back end to helps when you want to slide it off a trailer onto the ground. Hydraulic jacks also help.
kcdaniels
#7 Post by kcdaniels » Thu Jul 23, 2015 7:47 pm
Well more progress today...rails removed...two layers of carpet up...the deck is sound but old glue and the left over carpet rubber backing is still down :( I'm thinking now I might go with vinyl on the deck instead of the 10X. Paint..also plan on painting the pontoons...
Dan
1990 20' Sweetwater
Central Florida
photonfanatic
Re: restoration of 1990 Sweetwater
#8 Post by photonfanatic » Sat Aug 01, 2015 1:44 am
Can't wait to see the rest!! :drink2
kcdaniels
#9 Post by kcdaniels » Tue Aug 04, 2015 3:58 am
Well it's been raining every day...but is suppose to clear today... hopefully will be able to spray my logs and rail skins :nana Will post pictures if all goes well...
1990 20' Sweetwater
Central Florida
kcdaniels
#10 Post by kcdaniels » Tue Aug 04, 2015 3:48 pm
Primer sprayed !
1990 20' Sweetwater
Central Florida
kcdaniels
#11 Post by kcdaniels » Tue Aug 04, 2015 3:49 pm
1990 20' Sweetwater
Central Florida
kcdaniels
#12 Post by kcdaniels » Tue Aug 04, 2015 3:53 pm
And the final color :nana
1990 20' Sweetwater
Central Florida
kcdaniels
#13 Post by kcdaniels » Tue Aug 04, 2015 3:57 pm
This was my inspiration...
1990 20' Sweetwater
Central Florida
photonfanatic
#14 Post by photonfanatic » Wed Aug 05, 2015 2:20 am
So the black is just primer right? It would be super cool if you painted the fence to be the same color as the boat in that pic!
kcdaniels
#15 Post by kcdaniels » Wed Aug 05, 2015 4:11 am
Yes the black was the primer....the brown is as close to the tracker boat that I saw in bass pro...as far as the skin at the last minute I decided to use the brown then bring contrast with stripes and maybe some graphics...
We did a lot of prep work on the logs before primer...so far I'm very happy with the top coat...been a long time since I have sprayed two part top coats...but I still got it :nana
Waiting for the vinyl, but can do the under skining and will post more pictures as I go...
1990 20' Sweetwater
Central Florida
