PDB is Offline
PDB is Offline
#1 Post by HandymanHerb » Tue Sep 12, 2006 6:13 pm
Oh were oh were did PDB go, or I'm I the only one getting in, good thing Rock Star is on tonite :lol:
Toontroller
#2 Post by Toontroller » Tue Sep 12, 2006 7:21 pm
was ok at 6:00 but no dice now??????? :roll:
1991 Sun Tracker Bass Buggy 16
Evinrude 40
Bet I have the shortest Toon on this board also
#3 Post by HandymanHerb » Sun Oct 15, 2006 4:23 pm
Well it's been a while but PDB is down again, I was able to get on it once today about 2pm EST and that was it
Pop24
#4 Post by Pop24 » Mon Oct 16, 2006 2:00 pm
I was on it this morning and just tried to get on there again and no go!!
"My drinking friends have a lake problem"
2006 Bennington 22' TripleToon,Yamaha 150
#5 Post by HandymanHerb » Mon Oct 16, 2006 4:50 pm
I was on this after noon and then it went away again
Heatman
#6 Post by Heatman » Mon Oct 16, 2006 7:13 pm
If I use Aol I can't get on but if I just use my BB provider it works.
Sheridan, Indiana
#7 Post by HandymanHerb » Mon Oct 23, 2006 6:46 pm
PDB is offline again at 9:44EST or maybe it's just me again
looneytoons
#8 Post by looneytoons » Mon Oct 23, 2006 7:16 pm
We're fine here Herb. (10:12 est) Had a little down time this afternoon about 2-5 pm. But, has been fine since then. Don't know what your problem could be.
looneytoons
#9 Post by looneytoons » Mon Oct 23, 2006 7:22 pm
I take that back - at 10:11 it was ok - now it's gone again. 10:20. Must be an on again, off again thing. :wink:
#10 Post by HandymanHerb » Tue Oct 24, 2006 1:51 pm
I'm getting some thing new anyway
Error Occurred While Processing Request
Could not find the included template include/ini/cgivariables.cfm.
Note: If you wish to use an absolute template path (e.g. TEMPLATE="/mypath/index.cfm") with CFINCLUDE then you must create a mapping for the path using the ColdFusion Administrator. Using relative paths (e.g. TEMPLATE="index.cfm" or TEMPLATE="../index.cfm") does not require the creation of any special mappings. It is therefore recommended that you use relative paths with CFINCLUDE whenever possible.
Please try the following:
Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debugging Settings, and select the Robust Exception Information option.
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1)
Remote Address 72.40.136.106
Referrer
Date/Time 24-Oct-06 02:48 PM
Heatman
#11 Post by Heatman » Tue Oct 24, 2006 2:44 pm
I'm getting the same thing Herb.
Sheridan, Indiana
Toontroller
#12 Post by Toontroller » Tue Oct 24, 2006 6:35 pm
Well I can't get on either
Evinrude 40
#13 Post by HandymanHerb » Tue Oct 24, 2006 7:07 pm
Now I getting the main page but when I hit a section like general or off topic it says not found.
I got on for a few mintutes about 5:30 but nothing was new there and then after I finished running around and doing paperwork around 10 pm main page was there but I couldn't get in
#14 Post by HandymanHerb » Tue Oct 24, 2006 7:48 pm
Well i had it for a second, took me two trys to respond to toons post and then it was gone again
Diddyjo
#15 Post by Diddyjo » Wed Oct 25, 2006 3:29 am
HandymanHerb wrote:Well i had it for a second, took me two trys to respond to toons post and then it was gone again
That's because it's in the middle of the night...what the heck Herb, don't you sleep?? :D
2002 Godfrey Marine Sweetwater Challenger 180RE, 60 hp Bigfoot Mercury Mariner 2 stroke oil injected all on a sesame seed bun (LoadRite trailer)
