Sometimes, between 1am till 5:30 am, then I up and going again, someone got to make sure the jokes are readDiddyjo wrote:That's because it's in the middle of the night...what the heck Herb, don't you sleep??HandymanHerb wrote:Well i had it for a second, took me two trys to respond to toons post and then it was gone again
PDB is Offline
This is what I'm seeing this morning.
Error Executing Database Query.
[Macromedia][SQLServer JDBC Driver]Error establishing socket. No route to host
The error occurred in /WebFS/PontoonDeckboat/fusetalk/forum/include/common/globalsettings.cfm: line 22
Called from /WebFS/PontoonDeckboat/fusetalk/forum/cfc/ini/init.cfm: line 5
Called from /WebFS/PontoonDeckboat/fusetalk/forum/cfc/fusetalk.cfc: line 3
Called from /WebFS/PontoonDeckboat/fusetalk/forum/Application.cfm: line 28
Called from /WebFS/PontoonDeckboat/fusetalk/forum/include/common/globalsettings.cfm: line 22
20 : <cfset FTTMP_COMSETCACHE = CreateTimeSpan(0,0,0,0)>
21 : </cfif>
22 : <cfquery name="request.qGetSettings" datasource="#ds#" username="#dsusername#" password="#dspassword#" cachedwithin="#FTTMP_COMSETCACHE#">
23 : select * from ftdb_communitysettings
24 : </cfquery>
SQL select * from ftdb_communitysettings
DATASOURCE pontoonforums
Please try the following:
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 6.0; AOL 9.0; Windows NT 5.1; SV1; .NET CLR 1.1.4322)
Remote Address 152.163.100.65
Referrer
Date/Time 21-Nov-06 04:38 AM
Stack Trace (click to expand)
at cfglobalsettings2ecfm1227608760.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/include/common/globalsettings.cfm:22) at cfinit2ecfm555508242.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/cfc/ini/init.cfm:5) at cffusetalk2ecfc1997825845.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/cfc/fusetalk.cfc:3) at cfApplication2ecfm813913223.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/Application.cfm:28) at cfglobalsettings2ecfm1227608760.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/include/common/globalsettings.cfm:22) at cfinit2ecfm555508242.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/cfc/ini/init.cfm:5) at cffusetalk2ecfc1997825845.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/cfc/fusetalk.cfc:3) at cfApplication2ecfm813913223.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/Application.cfm:28)
java.sql.SQLException: [Macromedia][SQLServer JDBC Driver]Error establishing socket. No route to host
at coldfusion.server.j2ee.sql.pool.JDBCPool.requestConnection(JDBCPool.java:677)
at coldfusion.server.j2ee.sql.pool.JDBCManager.requestConnection(JDBCManager.java:123)
at coldfusion.server.j2ee.sql.JRunDataSource.getConnection(JRunDataSource.java:138)
at coldfusion.server.j2ee.sql.JRunDataSource.getConnection(JRunDataSource.java:125)
at coldfusion.sql.DataSrcImpl.getCachedConnection(DataSrcImpl.java:120)
at coldfusion.sql.DataSrcImpl.getConnection(DataSrcImpl.java:75)
at coldfusion.sql.SqlImpl.execute(SqlImpl.java:207)
at coldfusion.tagext.sql.QueryTag.setupCachedQuery(QueryTag.java:595)
at coldfusion.tagext.sql.QueryTag.doEndTag(QueryTag.java:443)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:147)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:357)
at coldfusion.runtime.CfJspPage._emptyTag(CfJspPage.java:1871)
at coldfusion.runtime.TemplateProxyFactory.resolveName(TemplateProxyFactory.java:290)
at coldfusion.runtime.TemplateProxyFactory.resolveFile(TemplateProxyFactory.java:77)
at coldfusion.runtime.TemplateProxyFactory.resolveName(TemplateProxyFactory.java:568)
at coldfusion.runtime.CFPage.CreateObject(CFPage.java:5038)
at coldfusion.tagext.lang.ObjectTag.doStartTag(ObjectTag.java:193)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:62)
at coldfusion.filter.CfincludeFilter.include(CfincludeFilter.java:30)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:93)
at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:43)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:80)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:47)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:35)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:43)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.CfmServlet.service(CfmServlet.java:105)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:252)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:527)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:192)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:348)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:451)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:294)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
21 : </cfif>
24 : </cfquery>
Referrer
Sheridan, Indiana
Sheridan, Indiana
- Texoma Toon
I am still locked out
Bob
Error Occurred While Processing Request
Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debugging Settings, and select the Robust Exception Information option.
Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322)
Remote Address 64.183.239.22
Referrer
Date/Time 21-Nov-06 07:19 AM
Bob
Referrer
- Texoma Toon
I'm hoping Whitney will give up some fish as well, Leaving tomorrow evening to set up and fish and nap on the boat!
Gotta love 70 degrees on Thanksgiving day
And yes thats above zero for the NORTHERN FOLK................
Hey Bob, do you post on the Texas Fishing Forum as well?
1991 Sun Tracker Bass Buggy 16
Evinrude 40
Bet I have the shortest Toon on this board also
Evinrude 40
- Texoma Toon
