DIY glove boxes?
Joseph Elliott
DIY glove boxes?
#1 Post by Joseph Elliott » Wed May 04, 2016 4:46 pm
The space I have available on my console doesn't allow for a normal size glove box. Does anyone have any experience making their own?
Alberta, Canada
Home made 16' pontoon, 1980 60HP Johnson- work in progress
BobL
Re: DIY glove boxes?
#2 Post by BobL » Wed May 04, 2016 5:04 pm
What about a "dry box" instead of trying to make anything? If you want it permanent then mount it somewhere.
http://www.overtons.com/modperl/product ... aQodmuQHMA
Joseph Elliott
#3 Post by Joseph Elliott » Wed May 04, 2016 5:34 pm
Because the hole already exists :)
Alberta, Canada
BobL
#4 Post by BobL » Thu May 05, 2016 7:12 am
Joseph Elliott
#5 Post by Joseph Elliott » Thu May 05, 2016 5:52 pm
I need something smaller, 8.5" wide, 4" high, 12" deep.
Alberta, Canada
walter
#6 Post by walter » Sat Jun 04, 2016 8:56 pm
I found and bought this one pre-made online, bought it and installed myself. They say measure 3 times and cut once, pretty sure I measured that hole 7 times before I made a cut. Turned out great especially since I didn't have a glove box before this one. Anyway, the box I'm sure is home made (or professionally made) just by using that plastic sheet material (can't think of the name right now) that you see used for many things on boats. I'm sure you could use the same concept to make whatever size you need. If you need I could take more close up pictures but it would be a couple weeks until we're back at our boat, just let me know.
xxxx (360x480).jpg (63.67 KiB) Viewed 4470 times
xxx (360x480).jpg (62.86 KiB) Viewed 4470 times
xx (360x480).jpg (53.04 KiB) Viewed 4470 times
x (300x400).jpg (43.02 KiB) Viewed 4470 times
115 hp Merc 4-str.
Collinsville, IL.
Boat on Ky Lake
Drago
#7 Post by Drago » Mon Jun 06, 2016 8:08 am
Walter,
Where online did you find that one? It is much nicer than the one that came standard on out 2007 Bennington.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
teecro
#8 Post by teecro » Mon Jun 06, 2016 8:25 am
Drago wrote:Walter,
I've seen similar at www.greatlakesskipper.com
walter
#9 Post by walter » Mon Jun 06, 2016 7:51 pm
I do think it may have came from that great lakes skipper place. I'll have to do some looking and digging to see for sure, I just looked at their website, and they've got alot more options now. I don't think I paid more than $50 or $60 for it. A guy could easily make one out of that starboard material and some stainless hardware but for about $60 I don't think your going to come out saving too much after buying the materials.
115 hp Merc 4-str.
Collinsville, IL.
Boat on Ky Lake
urbnsr
#10 Post by urbnsr » Tue Jun 07, 2016 2:43 am
Paul
Joseph Elliott
#11 Post by Joseph Elliott » Thu Jun 09, 2016 12:41 pm
Thanks for the responses guys :) In the end I built my own out of pvc sheet and wood.
Alberta, Canada
