Pooling water
Goudax3
Pooling water
#1 Post by Goudax3 » Fri May 06, 2016 4:11 am
I am curious what everyone does about water pooling in the seat bases. It is just from rain, the boat is normally on a covered lift so it is not a huge problem. But, if we get caught out in the rain or something like that it happens. I do not like leaving it because of possible mold issues. So I either mop it up or vacuum it out. Either way a pia. There is no drain holes in the seat bases and I do not know if I should add some.
Ross
Danbury Flowage/Yellow River, NW Wisconsin
2015 South Bay 520 CR
Evinrude 90 Pontoon series
DSwatloski
Re: Pooling water
#2 Post by DSwatloski » Fri May 06, 2016 4:23 am
put up some pics of the insides of your seats... might help us to visualize what might work.
Dave Swatloski, Northern, VA Lake Anna
2015 Harris 220 CWX - 2015 Mercury 4-Stroke 115 HP Command Thrust, Road King Tandem Axle/w disc brakes
Former 2003 Seapro CC, Yamaha 115 HP 4-Stroke
Former 1990 SunTracker Party Barge 24' Tracker 90 HP 2-Stroke
Onegun
Re: Pooling water
#3 Post by Onegun » Fri May 06, 2016 5:06 am
Are the compartments fully enclosed? On my boat, the longer compartments have the playpen as the back wall, and it's elevated off the floor for drainage. If the boat were to be angled slightly I can see some pooling occurring against the interior walls of the compartments though. Hmmmm.
If I were to drill drainage holes, they would NOT be thru the floor. They'd be thru the seat bases out onto the deck. And I'd drill them from the outside in so as not to accidentally mess up the floor where it could be seen.
Bill & Maggi - Hudson, Fl.
2013 Avalon LS 25' Party Barge
2015 Evinrude eTec 135 H.O.
2001 Ford F350 SuperDuty Lariat XLT Dually 4x4
Crewcab Longbed w/ 7.3 ltr Turbo Diesel
2004 R-Vision 30' Fifth Wheel Camper
Evanyj350
Re: Pooling water
#4 Post by Evanyj350 » Fri May 06, 2016 5:17 am
Maybe it would help to tilt the lift in the front so when it is raised, the water would head towards some drain holes you could drill into the downhill ends of the seat bases....
Small lake in Westen Mass
2016 Bennington 2250 SSRX/Yam 25hp HT
1997 Mastercraft ski boat
3 kids. 10,12, and 14. All skiers
2016 Ram 2500 tow rig
Goudax3
Re: Pooling water
#5 Post by Goudax3 » Fri May 06, 2016 6:37 am
I already have the lift tilted with the back low. That helps drain the floor well. In looking at the inside of the seats you will see the center is raised. The only low areas is what is against the floor. As mentioned I would not want to drill into the floor either. If I was to drill out the front I would damage the upholstery I think. Maybe the back?
Ross
sunedog
Re: Pooling water
#6 Post by sunedog » Tue May 10, 2016 4:54 am
My 2001 Bennington has plastic seat bases (rotomolded?) It came from the factory with holes drilled in a couple of corners drilled through the seat base and the deck. When I recovered my floor with vinyl, after re-installing my seats, I drilled through the vinyl and deck to replicate the way it came from the factory.
teecro
Re: Pooling water
#7 Post by teecro » Tue May 10, 2016 5:01 am
sunedog wrote:My 2001 Bennington has plastic seat bases (rotomolded?) It came from the factory with holes drilled in a couple of corners drilled through the seat base and the deck. When I recovered my floor with vinyl, after re-installing my seats, I drilled through the vinyl and deck to replicate the way it came from the factory.
Same with my Sun Tracker to which I've since added a couple more and enlarged them all to about 1/2"
If it gets in ya gotta help it get out....
FLOUNDERPOUNDER225
Re: Pooling water
#8 Post by FLOUNDERPOUNDER225 » Tue May 10, 2016 7:17 am
My Berkshire which is the same as the South bay already had drain holes drilled in the plastic bases, I added a few also in areas that were more prone to hold water
Pensacola FL
2015 Berkshire 231 RFC
Yamaha F-150
