Bansil and MamaTurtle create a getaway cruiser
Re: Bansil and MamaTurtle create a getaway cruiser
#31 Post by bansil » Thu Mar 29, 2018 9:43 am
Did you use all the colorful words i did?......before i went all stone age caveman..lololol
#32 Post by bansil » Thu Mar 29, 2018 4:27 pm
With all dr visits not much done, i got 4 panels sanded and painted...very pimp from 10 feet away...
2018-03-29 19.23.01.jpg (148.91 KiB) Viewed 33944 times
#33 Post by bansil » Mon Apr 02, 2018 4:04 am
spent some time yesterday on toon
I took apart remote to trace the 2 wires that came out the bottom and went to a blown fuse, it only took me an hour to put the damn thing back together...lol
Rebuilt fuel pump, diaphragms were in pretty bad shape
also messed with wiring some, what a mess (literally)
I put plastic wire loom over the wires that went through very rough bulk heads (they were not deburred)
Half the wires don't go anywhere????
Also found out why fuel sender wasn't working...no 12v + wire hooked up
also lots of 14 ga to 20 gage connections that need fixing
wire saver.png (500.8 KiB) Viewed 33898 times
jacked wiring.png (510.82 KiB) Viewed 33898 times
fuel pump.png (871.99 KiB) Viewed 33898 times
3 position switch.png (218.73 KiB) Viewed 33897 times
#34 Post by bansil » Wed Apr 11, 2018 6:06 am
not much to report, I tore all the wiring out, half of it wasnt connected to anything, nothing worked correctly
I did mount the live well pump, ran wire and hose (still need to secure and wire loom it, wire loom came in last night thanks to Amazon
hopefully Saturday all the wires will be covered and secured
gages are in the house so I can piddle with them at night
Also added air horn I had from another project, just cause
couple pictures...just because
ETA I will probably move the live well fill inside a few inches and move hose after looking at pictures, it looks vulnerable to damage if rear of pontoon swings out
pump wire.png (488.42 KiB) Viewed 33756 times
#35 Post by curtiscapk » Wed Apr 11, 2018 6:28 am
Looks great! you might want a cage of some kind over that pump? Just in case.....
sunedog
#36 Post by sunedog » Wed Apr 11, 2018 6:49 am
Got this from Amazon to work with the wire loom. Best $4.11 I've spent in a while.
https://www.amazon.com/gp/product/B005D ... UTF8&psc=1
#37 Post by bansil » Wed Apr 11, 2018 8:02 am
[quote="sunedog"]Got this from Amazon to work with the wire loom. Best $4.11 I've spent in a while.
https://www.amazon.com/gp/product/B005D ... UTF8&psc=1[/quote]
so it actually works?
I may order one in a few minutes and have it by the weekend work day!
#38 Post by bansil » Wed Apr 11, 2018 8:03 am
[quote="curtiscapk"]Looks great! you might want a cage of some kind over that pump? Just in case.....[/quote]
Yeah I haven't finalized what I want yet, I agree with you on that, I really need to buy a AC/DC Tig machine for the house
sunedog
#39 Post by sunedog » Wed Apr 11, 2018 12:28 pm
[quote="bansil"][quote="sunedog"]Got this from Amazon to work with the wire loom. Best $4.11 I've spent in a while.
I may order one in a few minutes and have it by the weekend work day![/quote]
Do it. And watch a quick Youtube on how to use it. (It's a little bit of a head scratcher without it.) I could get wires into the loom but it would take forever and it was touch on your fingers. This is well worth it.
#40 Post by bansil » Thu Apr 12, 2018 9:44 am
Well ordered yesterday evening, Prime and 2 day guaranteed shipping...ARGH!!!....this is the first time in 10 years that I get notified delivery is scheduled for the 16th
And check at lunch and it is on time for 16th still, I hope it is a screw up
Good note, extra wire connectors (glue/heat shrinked ones) are delivering tonight and 2" hole saw and arbor for Friday, hope to finish dash
Hope to splash this month
#41 Post by bansil » Sun Apr 15, 2018 1:12 pm
Got dash put together and now know what all wires go to what
Modified the basic switch panel by swapping out 2 switches and taking dremel to the double D's :mrgreen:
So i had a round hole to index volt meter
2018-04-15 15.59.52.jpg (87.77 KiB) Viewed 33676 times
2018-04-15 16.01.27.jpg (133.56 KiB) Viewed 33676 times
Top right
Horn
3 pos nav/mooring lights
Gags and n/off switch between bottom gages
#42 Post by bansil » Mon Apr 16, 2018 5:44 am
got some of this coming on Wednesday
minus the flowers,
#43 Post by bansil » Tue Apr 24, 2018 3:41 am
Long winded update
Well got the panel installed, all nav/mooring lights work now
Now onto the initial issue, she won't idle
I did this:
cleaned tank
checked pick up hose/tube
replaced primer bulb (would only barely idle and missing bad unless bulb was perfectly vertical)
pulled grey hose to check for old deteriorated liner (replaced)
pulled and cleaned factory engine mounted filter
replaced hoses on engine
rebuilt fuel pump
and still had issues, next step pull carbs and check for clogged jets due to ethanol
Guess what yup crystallized and green, that wasn't the biggest issue, very recently someone pulled carbs and replaced the needle and seat (brand new shiney brass and needle was polished and no scrathes)
When they put it back together, they tore the gasket (I found other part under engine) and this caused a massive air leak and explains the carb fuel mixture screws all the way rich
the engine would not run with any file due to massive leak after the throttle butterfly's, engine had 1/2 vacuum pulse for fuel pump also
and they apparently, due to dent on carb, used a hammer to knock loose fuel bowl and it broke off the high speed jet in the process
Looking into chamber before reed valves looks good
SO I ordered parts from BrownsPoint and am waiting
#44 Post by curtiscapk » Tue Apr 24, 2018 6:09 am
Wow! :o They did a number on those!
guy48065
#45 Post by guy48065 » Tue Apr 24, 2018 6:47 am
Good find on that gasket. They probably tried to re-use a damaged original & just hoped it would hold together during reassembly. It didn't!
Mark
Rush Lake, Atlanta, MI
