How many boat fenders???
dgreene62
#1 Post by dgreene62 » Sat May 26, 2018 5:03 am
Just got my new Bennington 22 SSRX. I'm putting together a list of things I need including boat fenders. The dealer only gave us 2 fenders with the purchase. I thought that didn't seem enough for a 23' pontoon.
How many boat fenders would you guys recommend on a 23' pontoon.
What size do you recommend?
Do you just get enough for one side and switch them back and forth or do you put them on both sides and let them stay?
2018 Bennington 22SSRX
Yamaha F150
steve1313
Re: How many boat fenders???
#2 Post by steve1313 » Sat May 26, 2018 12:41 pm
I have three, but most of the time if I need them at all I only use two. They are only meant to be deployed when in use. Don't leave them hanging off the side when you are underway! That's a rookie move. :roll:
smltooner
#3 Post by smltooner » Sat May 26, 2018 7:27 pm
I use two 8" fenders on my 22' pontoon.I only have them on the port side because that is where the side gate is, so I always tie up on that side.
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
#4 Post by ROLAND » Sun May 27, 2018 12:44 am
I keep three on board... I think they're 10" but not sure about that. I also have ez fender mounts on the rails on both sides of my toon so I can set them out lickity split without worrying about tieing them up at the correct height for whatever dock I'm at.
BG1
#5 Post by BG1 » Sun May 27, 2018 4:46 am
I have 6 on the boat - 3 for each side when rafting up although most of the time I am only using 2 at the tiki dock or gas dock.
EZ Fenders are highly recommended!
Brent & Gail
2018 Sweetwater 2186
Mercury 90 Command Thrust
martys
#6 Post by martys » Sun May 27, 2018 6:17 am
I have 6 on board, 4-10", 2-8". It's always about location and conditions. Rafting on a small lake is different than a large open bay.
I prefer Taylor type and styles.
Premier 22.5 Legend Triple
150 E-Tec
Baltimore, Maryland
zoom650
#7 Post by zoom650 » Sun May 27, 2018 2:41 pm
Six for me. Two for port and starboard and two for the bow, depending on the dock.
dgreene62
#8 Post by dgreene62 » Sun May 27, 2018 7:06 pm
Thanks guys. The maiden voyage today was fantastic.
Yamaha F150
Steve7
#9 Post by Steve7 » Wed May 30, 2018 8:04 am
I’m now in my seasonal lake. Turns out they had lots of wind this last week. After some experimentation, I now have three on the dock side, and two on the other side since I’m in a double slip. I shouldn’t have anyone in that slip much, but if so I want to protect that side. I will likely add a third. In the rear I have the AKUA fenders. I had one in the middle, but lost it the first night. The boat sits too high in the front to use them, it doesn’t contact the dock. For the others I am using ones that are 23” long, and fat (conventional from Walmart). Works well. I’m also using EZ Fender attachments. Just ordered two more. Those are really nice and affordable.
So...I recommend three on dock side, large and long with EX fender attachment.
2016 Ford F250 6.7
Grizzly Flats, Ca
#10 Post by bansil » Wed May 30, 2018 10:53 am
my problem is the toon next to us, it's rub rail/trim on deck is about 8 inches higher than ours
I need to get a couple fenders that are 24/36 inches long, I just hope he is careful when parking, we don't power in, I let her off on end od dock with bow and long stern line and she holds boat while I turn it off and then we just pull her in, I am afraid of hitting the other toon and taking my fence out :censored
Steve7
#11 Post by Steve7 » Wed May 30, 2018 12:00 pm
Yep, that’s what I’m afraid of. Maybe the AKUA fenders might work for you on that side to help protect you from your neighbor.
2016 Ford F250 6.7
Grizzly Flats, Ca
#12 Post by bansil » Thu May 31, 2018 3:34 am
Steve neat product line, I am going to toon tonight after work, to hook up some portable electronics and plan to measure for aluminum plates I can hang off rails and then put a couple fenders between it and my boat, like a "crush" zone
#13 Post by bansil » Fri Jun 01, 2018 2:30 pm
Well picked up some more fenders at wally world, and a pc of plywood, so i have 2 pcs 24x48, tied together and lashed to boat, should help with possible impacts that would take out the fence
2018-06-01 17.27.43.jpg (123.04 KiB) Viewed 17821 times
2018-06-01 17.28.10.jpg (159.55 KiB) Viewed 17821 times
So we have 7 fenders on board now :mrgreen:
Gonefishing
#14 Post by Gonefishing » Fri Jun 01, 2018 4:47 pm
I have 6, 3 on each side and I use ezfenders to hold them. That way I don’t have to move them if I need to tie up on weather side.
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
zoom650
#15 Post by zoom650 » Sat Jun 09, 2018 4:17 pm
For you guys sitting next to a boat that sits higher than yours, consider an anchor ball or two in between the two boats. There've been times in the past I used my center console's anchor ball as fender protection.
