Lame the 10% off code is gone?
gerard143
#1 Post by gerard143 » Fri May 31, 2019 6:21 pm
Went to place an order on pontoonstuff. Saw the 10% off code no longer works.
Closed out the tab and didn’t place the order.
Henpecked
Re: Lame the 10% off code is gone?
#2 Post by Henpecked » Fri May 31, 2019 8:37 pm
I like the seats at www.everythingpontoons.com anyway. You can choose the primary and secondary colors and they have benches that fold out into a bed/sun lounger. The consoles and captains chairs look better on pontoonstuff.
gerard143
#3 Post by gerard143 » Sat Jun 01, 2019 4:27 am
Lol went there and it’s a pontoonstuff owned blog lol. Familiar with the site u meant though. Everythingpontoon.com
Henpecked
#4 Post by Henpecked » Sun Jun 02, 2019 6:29 am
That's it. My bad.
Pontoonstuff should change their false advertising at the top of the page.
#5 Post by HandymanHerb » Sun Jun 02, 2019 10:18 am
Should have called and asked about it, they may have done a update that removed it
#6 Post by curtiscapk » Mon Jun 03, 2019 7:32 am
I'll let Mike know to change the graphic ... This is from James at Pontoonstuff
Hi Craig
Yes sorry about that I forgot to mention it to you.
I had to stop it. I’ve been needing to raise prices but I haven’t done it and a discount was killing me lol. All these tariffs are starting to affect me all of my supply lines.
gerard143
#7 Post by gerard143 » Mon Jun 03, 2019 8:01 am
bummer. I wanted to pickup the electric bimini top with the discount.
Henpecked
#8 Post by Henpecked » Mon Jun 03, 2019 4:47 pm
Boat Covers Direct has it for $839.
https://www.boatcoversdirect.com/produc ... 6d33545683
gerard143
#9 Post by gerard143 » Mon Jun 03, 2019 4:50 pm
That’s same price as pontoonstuff once you remove the remote control option. Restorepontoon has it for 829
steve1313
#10 Post by steve1313 » Tue Jun 04, 2019 2:19 am
Just make sure you read the fine print on that PWR-II Arm. I almost bought one, but you can't use it at speeds over 25mph. The top has to be fully deployed (flat against the fence) at that speed.
Liquid Asset
#11 Post by Liquid Asset » Tue Jun 04, 2019 3:25 am
The high end loaner boat I had the pleasure of using over the holiday had the power Bimini. I was less than impressed with it. As mentioned it has to be stowed at any sort of speed. Just floating around with the wind I thought it was going to get ripped off. I bet it's a high warranty issue for pontoon manufactures. Just operating it sounded like a couple of cheap can openers. I'm sure there are a lot of happy customers, but I'm glad my boat doesn't have one.
Just my .02
gerard143
#12 Post by gerard143 » Tue Jun 04, 2019 5:22 am
Seriously? This isn’t just the over precautionary typical bs warnings you see on stuff? Flat against the fence over 25 mph wtf. That’s ridic.
steve1313
#13 Post by steve1313 » Tue Jun 04, 2019 6:21 am
I went back and looked at the manufacturer web site and it specifically mentions to never have the bimini open above 25mph. Says it must be stowed with the boot on. All I know is my boat will run 40, which meant that if we had the top up and wanted to cruise, we'd have to lower the top or cruise at a much slower speed. I never installed it, so I can't verify for sure, but maybe others here can.
