Water Pump Impeller
- Capt Sully
Water Pump Impeller
I have a 90hp Yamaha and when I start it the water doesn't flow out. It's been sitting for a year and has 36hrs on the motor. Do you think the rubber water impeller has broken apart ? The impeller is in the lower shaft, I think ??
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
FVC USCG Auxiliary
Vietnam 66 / 67
Re: Water Pump Impeller
First try cleaning the proof tubing path, starting at the outlet end.
Mine sat for 3-1/2 years and the impeller was a little stiff but still fully functional. I highly doubt that the impeller disintegrated so badly that you get zero flow in that time frame. I used a piece of weed eater line and a touch of carb cleaner to ream it out a bit. Once I got a little bit flow, it took off.
- Capt Sully
Thanks Marc.....I'm going to remove the inlet plates and take a look...
2012 Xcurison X23C
FVC USCG Auxiliary
Vietnam 66 / 67
FVC USCG Auxiliary
Vietnam 66 / 67
Dirt dobbers love to fill up the pee hole.
If you're the original owner and you haven't run the engine without water, the chances of you needing a new impeller is nil. Yamaha impellers are really tough and long lasting.
Sometimes it takes a 30 seconds or longer for the water to flow out of the hole.
sounds like a long time.Bamaman wrote: ↑Thu Aug 27, 2020 11:12 pmDirt dobbers love to fill up the pee hole.
Kinda what I was thinking. He's from GA and I am too....those things don't waste any time. Gotta be careful taking a crap outdoors because those things will plug your b-hole before you can get your pants up.Bamaman wrote: ↑Thu Aug 27, 2020 11:12 pmDirt dobbers love to fill up the pee hole.
Mud dobbers! I have this in my tool compartment! Weed eater string long enough to run the whole tube.
- 20180525_135612.jpg (171.02 KiB) Viewed 19118 times
- 20180525_135551.jpg (165.21 KiB) Viewed 19118 times
On my Honda the hose came off the fitting.
Was here several years ago as RJF. Couldn’t find a way to revive that one so started new.
23’ Aqua Patio 90 hp Honda
Lund 1875 Crossover XS 150 Mercury 4st
